tremec mag xl driveshaft problems
dodger789
L.A.
john
2016 gt performance, whipple, stage 2 throttle body, rxt clutch, cf driveshaft, steeda subframe kit, 840 hp axles, X force w/ corsa long tubes and mickeys
Has anyone installed a Tremec magnum xl and had any driveshaft vibration problems due to driveshaft angle pitch. I have had nothing but 80 mph vibration problems although the first custom crome olly from AMP performance was a piece of crap jump rope I am now dealing with a carbon fiber shaft with vibration issues as well. They are making me another replacement and I hope that is the problem but any input on these issues would be greatly appreciated. Thanks.
db252
Equinsu Ocha
Bay Area, CA
16 GT Premium/PP/Nav
I run a QA1 carbon fiber with my mag xl. I also ran one with my mt82 and both have no issue whatsoever. All other QA1’s I’ve installed for other people run without issue. Plenty of issues with other brands and aluminum posted on here but success stories as well.
NoVaGT
Northern Virginia
2019 PP1 GT Kona
Aren't there shops that can balance drive-shafts on the car? I'd think that would be the best answer, rather than trying this drive-shaft, that drive-shaft. And if there's a pinion angle issue, such a shop should be able to identify that too.
dodger789
L.A.
john
I did start my research late after purchase and I would have gone with QA1 after the fact
dodger789
L.A.
john
IM allays the guy that gets the dented scratched or crooked crap first and then people think im the pain in the ass when i worry about my purchases. This cf driveshaft did come defective custom...they have already grinded on it twice for hours only to vibrate at a different speed. Driveshaft pros are making it good AFTER they experiment with mine....
db252
Equinsu Ocha
Bay Area, CA
QA1 just has a reputation for being right the first time and we pay for it but there is always an exception. Driveshaft pros should get you worked out. Tremec has a free app to check pinion angle and it’s a good baseline to use.
dodger789
L.A.
john
Thank you I will check out app
aleccesarenriquez
San Antonio, TX
Alec
2017 GT PP
I have the issue as well. Its confusing that the Q1A doesn't have the issue but the DSS does, if it's a pinion flange issue. I wonder if somehow the Q1A allows more flex (isn't so locked to one axis) without compromising strength?
revinto7
NY
07 shelby-gt 14 camaro SS 1LE
I Did this swap back in 2011 in my s197 , what a pain in the ass to get rid of DS vibes due to the angle of a 1 piece DS , this is the reason for the 2 piece factory version. It took me 3k in 3 DS At the time and 9000 rpm balancing +shimming the transmission and adjustment of pinion angle to get it somewhat smooth enough to where I was happy, good luck this is the only problem with this swap , maybe the QA1 is the answer it wasn’t around when I did the swap
whatsup62
Jupiter
Not sure apples to apples but I did a TR6060 swap and went CF route...no issues at all.
dodger789
L.A.
john
Y
yes this is becoming a pain in the ass. The other thing I found out about is indexing the new trans these things need to be engineered.
