TPMS Sensors
72&18
Charlotte
Doug
72 Mach 1, 18 GT350, 22 Bronco 2 Door
I picked up some OEM wheels to mount some cup 2's for the track. Do I have to run sensors or can I leave them out?
Thanks
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
I left mine out. By the time you notice the sensor info it's too late anyways.
Tomster
Beware of idiots
Tom
Thanks
If the OEM prices for the sensors are what is steering you away, get the ones tire rack sells. They are made by Schraeder, who makes them for Ford. I use them. They are 100% identical to OEM.
Kachow
Georgia
2017 GT350
I also have two sets of OEM wheels (Gen 1 and Gen 2) that I alternate between. I noticed my TPMS would fault when I switched to my gen 2 set. Do each have to be programmed to the car? They won't auto recognize?
MrMike
US
16 Mustang GT, 23 Bronco Wildtrak
I have the metal tire rack ones, highly recommend.
Egparson202
2019 Shelby GT350, 2018 Audi TTRS
I have multiple sets of wheels and the car recognizes them when I switch. On a rare occasion I have seen a fault, but it was easily reset with a cheap Amazon reset tool.
Tomster
Beware of idiots
Tom
The car will remember 2 sets of wheels. Swap them out and they should be recognized. Sometimes you see dashes, that usually clears itself. If it doesn't you use a TPMS reset tool.
Speedfreak
Central Florida
2017 GT350
I have two sets of track rims with sensors. I am a big fan of watching tire psi on the track. While they are not 100% accurate, they are useful to see and monitor when the psi's increase.
ChipG
Nashville TN
Chip
'20 GT350/'95 F250/'65 Fastback/'96 Cobra Project
Agreed. I have 3 sets of wheels/tires total and all have TPMS and pair fine. I leave the pressures screen up on track as an indication of the tires warming up (or overheating).
JAJ
Vancouver BC
2016 GT350 Track Pack
Exactly! In my experience, tire temps are the only worthwhile thing for the driver to monitor on the track. Everything else has a computer watching it that's way smarter and can react faster than the nut behind the steering wheel.
I have OEM TPMS in all of my rim sets and I use a Motorcraft TPMS19 tool to ensure that corner monitor assignments are correct when the car rolls out of the garage.
Tomster
Beware of idiots
Tom
Yes, tire pressure at the track is huge. That is what I monitor when I'm driving. The other stuff that you may want to reference is in front of you on analog guages (oil temp and pressure). Anything else is a distraction IMHO.
72&18
72&18
Charlotte
Doug
The two used wheels actually came with them, so I ordered two from Tire Rack to get a complete set. Thanks all.
Trace
Lake Ashby FL
Trace
2021 Mach 1 HP Elite A10 / 2022 Mustang GT Premium / 2019 F150 STX Sport 4x4
