Tow Strap + R Hooks
BierGut
New Jersey
2011 F-150
Okay, let me start by saying I don't want to have a "track" style tow hook on the front of my car -- certainly not the Ford Performance one that requires cutting the bumper grill. Additionally, I don't care for the "boy racer" look of the ZL1 Add on PLUS I am not a "do-it-yourselfer" (I know better!) so installing the ZL1 hook is something that would get pretty pricey once I paid for the hook and the installation by a competent shop. (for those who would suggest just unscrewing it) Which brings me to using the Ford owners manual method utilizing R (or J) hooks and bridle straps. Simple, affordable and fast if I need a tow off the track -- maybe not as fast as a tow hook protruding the from the grill, but still fairly straight forward. It could be wrapped tight and stored in what would be the spare tire compartment for use whether I need a tow from a public road or on track. Also would allow for a centered pull which would be great for winching onto the trailer if I wanted to go that route.
Thoughts? Downsides (ie track tow pressure on bumper vs flatbed)? Experiences???
Caballus
Over Yonder
GT350
Downside is that many (most?) clubs and tracks require a visible tow hook be attached in order to get on the track.
pilotgore
US
A bunch
Agreed, 2 of my local tracks require it be inserted before going on track.
pilotgore
US
A bunch
“Boy racer”.... ouch!!!
Have you considered having the ZL1 hook receiver installed, and only install the tow hook as needed? Since it sits behind the plastic grating the receiver isn’t visible. My mini’s have all had a threaded receivers behind a small access panel on the bumpers for that purpose. The bmws I’ve owned were the same. Seems like a clean way to do it.
ZX3ST
STL
2018 GT350, Kona Blue, J3116
Agreed.
OP, do you realize the ZL1 hook can be unscrewed in a matter of seconds, leaving the bracket installed?
If the answer is yes, and it exceeds your comfort level of "do it yourself", then I'm glad you're not in my run group.
While the hooks can help avoid additional damage from the tow vehicle when being pulled from the sand pits, it's also a courtesy to other drivers. How would you feel if another driver cost everyone 30min of their track time because they couldn't get it towed to the paddock in a timely manner?
No personal experience with your proposed solution, but given that the tow truck will be puling at an upward angle, I think bumper damage is likely. The J hooks are designed for securing the car to the flatbed, not for towing.
oldbmwfan
Chicagoland
2017 GT350R
Not gonna work when you're belly-pan deep in pea gravel. The track tow operators are not there to protect your car; they are there to clear the track. They will hook up to the first thing they can and pull you straight out. If that means your bumper gets torn off, or your control arms get bent, that's sort of your problem. The ZL1 tow hook isn't ideal because it's off-center, but it should be strong enough to pull the car free without incremental damage if it can roll at all, and that's what you want. It's the option with the least invasive installation (i.e., no modification or cutting of stock parts), which is why it's popular despite being imperfect. And, if it does cause damage, it's to the relatively cheap lower grill mesh insert only.
I can't think of any track tow operator who's going to wait around while you try to hook up J-hooks and run a strap out the front of the car, and typically the track does not want you outside the car on a hot track at all in the first place.
BierGut
New Jersey
2011 F-150
Some good points -- the pea gravel aspect is the main one. My experience with track tow operators, however, has been the exact opposite the past 30 years with HPDE -- nothing but patience and concern for the car when it needed a tow. While I've only needed a tow a handful of times - they have always been great. But, like i said earlier -- can't argue with you point about the car if it's burried in gravel and unharmed in any other way.
BierGut
New Jersey
2011 F-150
This is the best reason to install the ZL1 or FP hook, no question. Thanks.
oldbmwfan
Chicagoland
2017 GT350R
Glad that's been your experience ... I've mostly seen them want to get the track cleared ASAP and minimize the time anyone is outside a vehicle. Fortunately I've not had many experiences with it, so my n is small ...
BierGut
New Jersey
2011 F-150
It was a little different racing. That's a "get it outta here" senario. But like mentioned above -- the best reason for a real tow hook is to save time for the others driving. So it pretty much trumps trying for a workaround.
Inthehighdesert
NM
Charlie
Going to go sideways now. Logic just got deployed.:idea:
