Track Day Drivers - What are you doing about the lack of Tow Hooks on the car?
Discussion in 'Shelby GT350 Mustang' started by Essex Wire, Feb 25, 2016.
Tags:
  1. krt22
    krt22 Well-Known Member
    Vehicle(s):
    2016 GT350 Track Pack
    May 27, 2015
    CA
    4,555
    2,013
    0   0   0
    hooking that up will be a real PITA if you are in the mud or a gravel pit. If you need a tow at the track they are trying to get you off the track ASAP so it can go hot again
  2. cloud9
    cloud9 Well-Known Member
    Vehicle(s):
    2019 Mustang Bullitt
    Aug 12, 2015
    Sioux Falls, SD
    233
    126
    0   0   0
    That's my plan for BIR this weekend, and I may throw a fleece sleeve from one of my wheel tie downs in the glove box to put around the strap where it intersects the front clip in front of the hood. If the S197 STB held up, the GT350 will probably be strong enough to get you out of a gravel trap if they can get to the front of the car. The strut tower bolts are twice as big and don't tie into the strut mount like the S197 did.
    This is a big deal and I hope someone solves it soon. I'm more worried about a track side mechanical than a crash. If you crash you've already got damage, unless you're just sunk in a gravel trap. After three clutches, two gear boxes, a slave cylinder and engine wiring harness issues on the Boss, I'm hoping this car holds up on track better. From everything I've seen it does and will. We beat on them pretty hard at TA and no issues. That said, when you whale on any car under track conditions, things break.
  3. cloud9
    Vehicle(s):
    Aug 12, 2015
    Sioux Falls, SD
    233
    126
    0   0   0
    Watson sells the tubular chromoly rear bumper beam with the tow hook attached like in the photo. It will work on any S550. The front doesn't line up with the GT350 front fascia and radiator ducting. I thought about getting the rear one installed, but in the last seven years running Mustangs I've never used it. I always needed the front.
    mattlqx likes this.
  4. REAZO
    REAZO Well-Known Member
    First Name:
    Ron
    Vehicle(s):
    2016 GT 350
    Feb 26, 2016
    61
    65
    0   0   0
    This is really a great job. Well done. Did you do it yourself or work with a local fabric/cover shop? My local tracks (PBIR in Palm Beach, Sebring) doesn't have much sand, so this is great.
    Also, excellent color choice. Mine is same combination! Love it.
  5. cking
    cking Well-Known Member
    Vehicle(s):
    17GT350AG/BS-MGW/UPR/ABLIP
    Dec 27, 2016
    852
    236
    0   0   0
    Good info on the tow strap, I found some of those T link with pear and order two Now I'll pick a tow strap from harbor freight and have my canvas repair man stitch me up one also. I Think every car should have one in the trunk. Cause the Guys I've seen towing are NOT carefull
  6. ChevyNick
    ChevyNick Active Member
    Vehicle(s):
    2016 GT350
    Jun 30, 2016
    Topeka, KS
    I use the rocket science racing tow hook, with a center mount.
  7. danhuberty
    danhuberty Dan Huberty
    First Name:
    Vehicle(s):
    2017 ShelbyGT350
    Dec 29, 2016
    Lakeville, MN
    Rating:
    100%
    1   0   0
    REAZO likes this.
Loading...
Share This Page
