Shifting_Gears
- Sep 13, 2018
- South Florida
- 2016 Mustang GT
Torsen is superior in everything except straight line traction. It will fight for traction more than a clutch style LSD. With a traditional LSD once the clutches engage you get a locked differential until there is no more variance in wheel speed, the the clutches no longer force the axles to turn at the same speed.
As mentioned, the Torsen can exhibit the characteristic of “hunting” for which wheel to lock during hard, straight line acceleration where traction is limited at both wheels.
However - I would venture to say there’s very little performance difference between the trac loc LSD and Torsen in actual drag times.
The trac loc is tried and proven, but it is a wear item. Eventually you’ll get one wheel peel and the more you excercise the diff with acceleration under hard cornering (IE; road course or autocross), the faster it will wear. Spider gears can also wear. It’s truly not HARD to rebuild, but you have to pull the LSD and ring gear assembly from the axle. You can also upgrade the clutches.
I LOVE LOVE LOVE the Torsen in my GT and wouldn’t EVER desire another trac lok over it. It transforms the car’s ability to put power down in a corner with out drama.
