Timing Sprocket Issues on 15?????
Jeff_oddo
Colorado Springs, CO
Jeff
Mustang GT Premium
Yes. Oil pump gears
Jeff_oddo
Jeff
Mustang GT Premium
What's the difference between the ford racing Boss oil pump and the MMR Hurricane oil pump? Do they both have billet oil pump gears inside? Also would it be cheaper and easier just to purchase the billet oil pump gears and install on the stock oil pump? I'm in the process of putting together a parts list to upgrade those components over the winter.
RockStang
AA county MD
Joe
2016 GT Whippled
Good question. I would like to know for the future as well. Seems like it would be easier to change the oil pump vs pulling out and changing the gears but I don't know wth I'm talking about.
Arclight1960
Los Angeles
Leor
2015 Mustang GT
Show me the people with stock ones broken.
Internet problems get blown up too easily. People take what one guy says and turn into fact.
I've seen proof of one of these broken so far. It's not a widespread problem, especially at stock power levels. Boosted, it's probably good insurance.
Hi everybody
Don’t want to jump the gun but my stock 2015 Gt has bent valves on number 5 cylinder I don’t track the car and out of warranty with 60k
Will update the problem as soon as I know
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Hi everybody
Yep, it happens. Mechanical failures happen.
s550cano
Clarksville, TN
2017 Race Red GT
Hi everybody
How did you bend them? And how did you find out they were bent? Car running bad?
Jackson1320
California
Jaxson
2015 mustang gt
Changing the gears is very straightforward if you’ve already got to the pump it’s a lot cheaper to just change the gears. To my knowledge the boss pump does not come with billet gears. MMR takes a stock pump rebuilds it to their specs with their gear
Edit: I double checked and the boss pump is exactly the same as 15-17 gt
Jackson1320
California
Jaxson
2015 mustang gt
The 15-17 have had problems with the secondary timing chains breaking or stretching or jumping time at high rpms. I recommend upgrading these and use gt350 primary chains anytime you open up the engine
Or you floated the valves
Arclight1960
Los Angeles
Leor
2015 Mustang GT
Hi there,
I had it diagnosed by a mechanic that said number 5 cylinder bent valve!
Not sure which valve yet.
Took it to the ford dealer will know in a few days what’s wrong...
IMO the timing chain skipped a tooth...
A few days before it happened I started the car drove for five minutes and I heard her a bearing sound a whining sound very slight and it went away then a few days after started the car again drove for five minutes at a stoplight it started shaking so I pulled over and parked
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Hi there,
What is the basis of your assumption? Which chain? Primary or secondary? You are just guessing at this point.
Arclight1960
Los Angeles
Leor
2015 Mustang GT
Hi everybody
Just an update they haven’t removed the timing chain cover but the mechanic at the ford dealer found a broken spring on one of the intake valve
I’ll update more tomorrow
