Thoughts on replacing timing chain?
tdstuart
Arizona
Triston
2015 Mustang Gt Premium
So I have my timing cover off... should I replace my timing chains? They look a little worn and I have 101k miles on the motor.
If I replace them is it okay if I replace the primary and not the secondary?
I found the primary chain for about $70 but I have only found the secondary chain for $130.
Any opinions or thoughts would be greatly appreciated?
larr12
Alberto
2020 Mustang PP1
I would replace both at that moment.
tdstuart
tdstuart
Arizona
Triston
Do you know where I could get a factory replacement secondary chain or just one for cheaper in general?
larr12
Alberto
2020 Mustang PP1
bauern
somewhere else
Robert
F150 Powerboost
Secondary chain part #BR3Z6268A, less than $30. each.
tdstuart
tdstuart
Arizona
Triston
Thank you! Forgot I had access to ford dealer connect and I pulled the part number off of there and found it on fordparts.com
shogun32
Northern VA
so I have to ask, why are the timing chains so REDICULOUSLY TOO long? They should be JUST long enough so you can walk them off the sprocket. No wonder any minor hiccup in the tensioner and the motor grenades.
And apparently Ford also used oil-pressure as the sole force on the tensioner? What freaking moron thought that up? You always use a one-way ratchet so that it is impossible for the piston to retract...
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Does anyone make these for the coyote?
tdstuart
tdstuart
Arizona
Triston
silverbullet85
San Diego
2019 Gt
They are oil pressure and spring pressure, otherwise they wouldn't require a pin to be released after they were installed. before your engine gets oil to the tensioners they wouldn't have tension on the chain and the chain would jump every time the engine is started if the springs weren't there.
Jackson1320
California
Jaxson
2015 mustang gt
The boss tensioner is the only way to go. The spring in the tensioner is weak and allows the chain to have slack until oil pressure builds. This is also one of the reasons for the 2K rattle. When you let off the gas the oil pressure drops allowing the chains to slack. I use gt350 primary chains. They are a slight upgrade and they’re actually cheaper. I also recommend a secondary tensioner flip bracket
