The damn fuel pump issue.....
SBR70.3
Edmond, OK
2021 Mach 1, 2023 Explorer ST, 2019 GTI (back up track toy), 2026 Colorado ZR2
Tracking my M1 today. Hot AF in Oklahoma (100 F by 11 am). I did swap the stock fuel pump out for the DW400 but still having fuel cut issues when tracking out of a fast left turn. Now I am getting fuel cut/hesitation when I am over 6500 RPM. Livernois Flex tune. I did go from using full E85 to a 50/50 blend of E85 and 91. The only other change was removing the driver side fog light insert. Stupid question but would that allow THAT much more airflow through at high speeds to cause the cutting over 6500?
Am I looking at a complete fuel system overhaul if I want to keep tracking this car? If anyone has found a solution, please chime in.
I guess since I won't be setting any personal best lap times today I can swap those DBA pads and let y'all know if they are worth buying.
John S
Novi, Michigan
2022 Mach 1 HP
KPM supposidily resolved the sweeping left turn starvation issue with improved bucket/venturi design (All the Dark Horse Track Attack cars switched to their KPM800 pump module) and the ram air into the air cleaner had no impact on intake temperature or performance on my Mach 1 exept giving bugs and dirt debris a straight shot into the filter, the stock cold air s-bend path to the air filter has plenty of high pressure flow. I just installed the KPM pump in preparation for HPDE events and I'm working on mounting a Radium Filter w/6-micron microglass media. I run E85 and I wasn't going to wait for the recalled OEM pump to give out or worry starvation concerns.
SBR70.3
SBR70.3
Edmond, OK
I will say the fuel cut is a bit better with the DW400 compared to the stock pump but this cutting over 6500 is new. But I will look into that KPM kit. Thank you!
engineermike
La
2018 GTPP A10
The gen3 bucket fill rate from a single saddle side is sufficient at the stock power level on gasoline. Othwise it needs to fill from both saddles if you’re at wot long enough. If starvation in turns is the cause, a dw400 was never going to fix it. I do wonder if your venturi is obstructed per the recall description.
Adding a tiny amount of airflow wouldn’t cause this.
2016 Mustang GT PP w/ Voodoo
I run a KPM1000 and its been great. The unit doesn't have an in-tank filter, but they have an option for a filter solution now.
That's cool the Dark Horse track cars are using them.
allfivefifty
Jaime
2022 Mach 1 HP
Yes, known issue for people that track the car. Usually high lateral g's and depending if you are on high grip tires/ skill level. When i was at Daytona I saw steeda testing the KPM fuel pump. I haven't had issues with KPM 800 and E85. Install was a PITA. BTW, off topic but you might also want to invest in oil baffles or better oil pan since that will be a more costly repair than cavitating the fuel pump.
As for removing the Mach 1 light insert on the driver's side to allow more air, i haven't had any issue. I did see that someone put a filter cover on theirs to minimize the turbulent airflow causing MAF issues. See minute 1:31 in the second video.
K Myers
Ft myers Fl
Maurice
2015 GT Mustang
I have the same system this is how I installed my fliter
sdskinner73
Indiana, United States
Shawn
2018 premium GT A10 3.55s
At what power levels does a fuel system become important? I am looking to go ESS next year. G2 kit. Goal is 650-700 wheel. They use the DW415 it looks like. Hoping that is enough for my goals.
engineermike
La
2018 GTPP A10
Supplying enough fuel for a drag car or occasional street blasts is completely different from top speed runs and track days, especially with long sweepers. Keeping the bucket “full” is basically optional for street and drag use.
K Myers
Ft myers Fl
Maurice
2015 GT Mustang
In order to run e85 in needed a fuel system so I went with th KPM fuel system makeimg 728 whp on e85 @ 97° with 75% humidity
K Myers
Ft myers Fl
Maurice
2015 GT Mustang
The KPM 1000 hp Fuel Module uses two high-performance Bosch racing fuel pumps rated at 300 liters per hour each (totaling ~600 L/h), alongside dual-acting Venturi lift pumps.
SBR70.3
SBR70.3
Edmond, OK
KPM800 ordered. Hopefully this will fix the issue. Will report next track day.
K Myers
Ft myers Fl
Maurice
2015 GT Mustang
Did you get the filter you will need it because it doeaent have filter socks on it
John S
Novi, Michigan
2022 Mach 1 HP
Details, please? I installed a Deatschwerks Filter on my valve cover but I'm going with a larger Radium unit with a 6-micron micro-glass cartrige element to better protect the direct injection system over the 10-micron stainless mesh media. It gets cramped under the strut tower brace to fit the larger radium filter and still have access to the dipstick so I'm still "developing."
