Sync3 3.3 Ford-EVO Startup / Shutdown Animation
nghtmaregt2
Julien
Mustang GT
Maybe someone can help me with this. I had the same issue as above and changed the same values but still have the Ford logo at shutdown. Anything else that might affect this?
zero_chance
Dismember
Arizona
JD
2017 GT Premium w/ Performance Pack
So are those AB mods listed getting the startup / shut down screens to the Cobra : Ford perf screen at the beginning of the post? If so, what sync version do you need for that? 3.3?
zero_chance
Dismember
Arizona
JD
And is 3.3 unique to 2019 APIM only? Need to know which one to buy, 18 or 19.
el-guapin
el-guapin
LSU - Geaux Tigers!
www.tesla.com
1949 UFO
To my knowledge, Sync3 3.3 was the first version to have that startup /shutdown image.
zero_chance
Dismember
Arizona
JD
I’m getting the same issue. Ford Perf on startup and ford on shut down
zero_chance
Dismember
Arizona
JD
Maybe not related but I’m wondering if our hardware won’t allow for the shut down screen? The folks it’s working for are 18 and newer, nightmaregt2 and I are 17 and possibly older. I even mimicked a GT500 as built data for the line that corresponds to the shutdown screen and each change had zero effect, stuck with Ford.
zero_chance
Dismember
Arizona
JD
Will test on my neighbors 18 tomorrow to see if my theory holds water.
zero_chance
Dismember
Arizona
JD
Mine is a 2016 so maybe you are correct. I can post a picture of my data if it helps.
I would just so we all have access to it. I’m losing hope for the shutdown since copying the line from a GT500 has no effect, but who knows. Will be trying on my neighbors this afternoon and will post results from his 18.
zero_chance
Dismember
Arizona
JD
@zero_chance and @nghtmaregt2, If you try the code for the Ford GT, do you get both startup and shutdown? or does Ford Pony Shutdown comes up?
Ford GT
Startup: 7D0-02-01: xxxx xDxx xxxx
Shutdown:7D0-03-01: xxxx x4xx xxxx
Let me give it a try. My neighbor with the 18 cancelled on me so I won’t be able to test out that theory.
zero_chance
Dismember
Arizona
JD
Ford GT
Modifying to those parameters gave me the generic blue oval on start up and shut down.
el-guapin
el-guapin
LSU - Geaux Tigers!
www.tesla.com
1949 UFO
That's Interesting. Ford GT theme and startup was present on version 3.2 and was still available on 3.3 Not sure what could be causing your issue. Might be APIM hardware related.
zero_chance
Dismember
Arizona
JD
I’m pretty sure it’s just 17 and older APIM’s for whatever reason are limited. Probably a hardware limit.
