UofMEngineer
Yes. From memory they're both linked to the splash screen config byte.Use "10" for both startup and shutdown?
THNX!. I'm currently using the Ford GT:Yes. From memory they're both linked to the splash screen config byte.
So i tried using 10 to change the startup screen. It did not work. I mean, the check digit is a single digit (Startup: 7D0-02-01: xxxx xDxx xxxx)so when i attempt to input 10, it only grabbed 1. Same results on shutdown screen(Shutdown: 7D0-03-01: xxxx x4xx xxxx). Am I to erase the entire block of 4 digits (xxxx) and replace it with 2 digits(xx) then make those 10?Mustang EVO - 10
7D0-02-01 = xxxx 10xx xxxxSo i tried using 10 to change the startup screen. It did not work. I mean, the check digit is a single digit (Startup: 7D0-02-01: xxxx xDxx xxxx)so when i attempt to input 10, it only grabbed 1. Same results on shutdown screen(Shutdown: 7D0-03-01: xxxx x4xx xxxx). Am I to erase the entire block of 4 digits (xxxx) and replace it with 2 digits(xx) then make those 10?
Thank you for that clarification! So the startup and shutdown splash are set in this line code 7D0-02-01. Does the theme (7D0-03-01) uses the same 10 or is it different?7D0-02-01 = xxxx 10xx xxxx
7D0-03-01 ==> The one you have here is for the theme (Ford GT), not the splash.
The theme would use 0, 1 or 4. 0/1 are the two slightly different default Ford themes, 4 is the GT theme. There are more unique splash screens than the generic UI themes.Thank you for that clarification! So the startup and shutdown splash are set in this line code 7D0-02-01. Does the theme (7D0-03-01) uses the same 10 or is it different?
Thank you!!. I’ll try to set that splash screen again today.The theme would use 0, 1 or 4. 0/1 are the two slightly different default Ford themes, 4 is the GT theme. There are more unique splash screens than the generic UI themes.
I'll try and take a peek tonight - I have the new APIM installed, but haven't hooked up the computer since the original install.Any luck with this?..
If it still doesn't work, might need to toggle one more config value. It wasn't clear if the splash setting would override the brand value.Thank you!!. I’ll try to set that splash screen again today.
THNX. Do report your findings!I'll try and take a peek tonight - I have the new APIM installed, but haven't hooked up the computer since the original install.
I got the startup splash screen to work by modifying 7D0-02-01= xxxx xDxx xxxx(Ford GT) to xxxx 10xx xxxx. But the shutdown splash screen changed to the generic Ford one. I left 7D0-03-01= xxxx x4xx xxxx the same which I had set for the Ford GT. I was gonna try changing that value to either 0 or 1 but Started Raining.If it still doesn't work, might need to toggle one more config value. It wasn't clear if the splash setting would override the brand value.
So, brand id should be 0 (Ford), which it likely is already. Theme should be set to 0, and splash should be the 10 for the "ford-evo" theme. That should trigger the right shutdown animation.I got the startup splash screen to work by modifying 7D0-02-01= xxxx xDxx xxxx(Ford GT) to xxxx 10xx xxxx. But the shutdown splash screen changed to the generic Ford one. I left 7D0-03-01= xxxx x4xx xxxx the same which I had set for the Ford GT. I was gonna try changing that value to either 0 or 1 but Started Raining.![]()
I had a few minutes today to hook up my software and ended up with the same result - the normal Ford splash on shutdown. I may have some more time to mess with it on Sunday.
This worked!!.. Thank You!!So, brand id should be 0 (Ford), which it likely is already. Theme should be set to 0, and splash should be the 10 for the "ford-evo" theme. That should trigger the right shutdown animation.
You're welcome. Just had to find a spare minute to hunt down the right config values in the code.This worked!!.. Thank You!!
So this is what I ended up doing:
7D0-02-01= xxxx 10xx xxxx
7D0-03-01= xxxx x0xx xxxx
THNX Again!
