Suspension upgrades, alignment time question
NewTekBuzz
Flint, MI
Tim
2019 velocity blue GT 6M - 2015 Black GT 6M (sold)
got most of the Steeda upgrades and just added new rims and tires. Steering wheels is a bit cocked.
Can a simple shop do all the required checks or is a dealer my best bet?
Last mod will be springs for a slight drop.
T.I.A.
1 old racer
Fontana CA
Will
when are you doing the springs? if soon, and you are not going to drive too much then take it too a alignment shop. I would not recommend a dealership
Dave TBG
Patiently waiting...
New Jersey
'19 EB 201A, '86 Porsche 944
You need an alignment, that's for sure. You'll need to do it again after you change the springs. Why didn't you do it all at once? The dealer can probably do a decent job but they may only align to factory specs, this may not be what you want. Most tire stores do the same thing, specs are often based on VIN number.
Find a shop that has a good reputation for alignment and suspension work. They don't need to be Mustang experts (it wouldn't hurt), just suspension experts.
PoppinJ
2018 Mustang GT Premium
Call the shop ahead of time to make sure they will match what specs you request instead of factory specs. I found a frame and alignment shop and had every mesurment front and rear that I wanted, including tolerances and had them set it that way. 200 bucks.
NewTekBuzz
NewTekBuzz
Flint, MI
Tim
I’m not looking for anything specific, it’s just noted on all the documents for the Steeda parts that an alignment is required.
I’m assuming I just need the factory specs? This is my first modded suspension so I’m looking for guidance.
Thanks
Cardude99
Phoenix, AZ
Sam
2018 Ecoboost
Depends are you looking to track it at all (road course, autocross, etc...) or just normal street driving?
Bluemustang
2015 Mustang Base GT
Thanks
You'll want different alignment specs than a factory to take advantage of the upgraded suspension. Depends also on what kind of driving you plan to do. When you upgrade the suspension "just align it" or "everything in green" is not good enough anymore. You'll want a much tighter alignment and probably more negative camber.
NewTekBuzz
NewTekBuzz
Flint, MI
Tim
Thanks guys, This is strictly a street car.
NewTekBuzz
NewTekBuzz
Flint, MI
Tim
Can you provide me with what this should be?
yote41
pa
16 gt
^ i would also like to know specs for after market springs on street car.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Search through posts from @BmacIL. I've seen him post alignment specs numerous times.
JR
For a Street car
Front
Camber: -1.5
Caster will end up around 7.0
Toe: 0.00-0.03 per side, 0.00 steer ahead
Rear
Camber: -1.2-1.3
Toe: 0.10-0.12 per side, 0.00 thrust angle
Wolvee
Williamsburg
2021 Shelby GT500
For a Street car
Front
Camber: -1.5
Rear
Camber: -1.2-1.3
How much for a difference is there for a Daily that also Autocross?
BmacIL
Enginerd
Naperville, IL
Add another degree (or more if you can) of front camber and 0.7 of rear camber. Otherwise pretty much the same. You may be inclined to go to a slight toe out (negative) for autocross, too.
Cardude99
Phoenix, AZ
Sam
2018 Ecoboost
I daily (9k miles per year) and auto cross as well about 8 events a year. My car just turned a year old and with a stock alignment the outside shoulder of all of my tires is gone. If you plan on doing auto x do not get a street alignment unless you want to buy tires every year.
Follow what BMAC said and up the camber to -2.5° front and -2° rear. I have not done it yet but will be once I get my suspension components and new tires later this year.
