Suspension Malfunction Error after Spring Install, Dealer fix only ?
NoXiDe
GA
GT350
Personally, I think the magneride sensor was loose. I recall it being a PITA to get snug. I even called a buddy to complain about it and was a bit worried after the install that I'd get some code. Fired the car up and no issues. Per CJ Pony, they do recommend you disconnect the sensor which is the guide that I followed.
Kramerica
2017 GT350
Ahh gotcha, thanks for the heads up. I just ordered BMR springs, sways bars and end links so I'm trying to do my research ahead of time regarding ride height recal and mag ride reset. Just wondering if that's necessary or best practice?
NoXiDe
GA
GT350
I've had mine in now for about 5,000 miles and I didn't do anything special.
gsxr1300
MA
Jason
2023 Mach 1 2015 Mustang GT PP (Sold)
Has anyone been able to re Cal your ride height.?
I just got this error.
fpa1974
GA
'19 GT350R
Yes, forscan works like a charm for recalibrating ride height. That does not mean that is going to fix this error though…
gsxr1300
MA
Jason
As of now, it's showing a error in each rear height sensor and a sensor supply fault. I cleared them to see if they all keep showing but now it only shows the sensor supply fault. So possibly a short somewhere in the harness, I'm assuming the fault means no power is going to the rear sensors. Can't find any pinches in the harness anywhere or anything unplugged. So gonna keep following the harness
what did you use to show these codes?
