Suspension Advice Needed (school me)
mysta_sandman
MA
Domenic
2017 GT350
Recently, I bought Eibachs to drop my car an inch all around and now I'm thinking of grabbing some 6GR wheels. I installed the 350 Fenders a while ago so I'm either going square (305/30/19) or staggered.
Two questions though.
One: do I need to rework my suspension to accommodate such larger wheels and tires?
Two: With the larger size in mind, what could make my drive more pleasant on a day to day basis? Driving in Boston and the North Shore is pot hole city and I want to try and bang it all out.
I've been thinking of adding a front sway bar and new links but idk what route to take first.
Thanks!
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Endlinks won’t do anything, they are just a metal bits that connect the swaybars to the rest of the car.
unfortunately I don’t know how much extra room you gain from the GT350 fenders, but you need about 25mm or 1” of offset In the front to push the 11” wide wheels with 305s away from the strut body, since the P6GR 11”s come with a ~50mm offset suited for the rear suspension.
you’ll need either 25mm bolt on spacers OR better yet, install 1” longer ARP studs in your front wheel hubs (or replace the hubs with ones with the studs pre-installed) and run 1”/25mm slip on spacers. Thats what I’ve got on my own car and many of us running square 11”s go the extended stud route. Extended studs with slip on spacers are more bulletproof than bolt on spacers (with double the number of fasteners and points of failure keeping your front wheels attached).
have fun!
NightmareMoon
The question is if you would also need camber plates. Those of us with square 11”s under stock GT fenders do need camber plates (not bolts) to shift the struts and tuck the wide front tires under the GT’s fenders
Cardude99
Phoenix, AZ
Sam
2018 Ecoboost
I would argue you always need camber plates cause driving is so much more fun with more negative camber
Vicr
Fortuna Foothills, AZ
Vic
2015 Mustang Ecoboost Premium
Caster/Camber plates = correct alignment = no irregular tire wear. The speed shop that did my suspension highly recommends the Maximum Motorsports CC plates.
Cardude99
Phoenix, AZ
Sam
2018 Ecoboost
= Smiles for days
However I recommend Steeda plates
NightmareMoon
Yeah, no. The MM plates will (for many people) cap out at 2 degrees camber, and we're talking about going to opposite direction, trying to get MORE camber, not less. If you're trying to correct to a factory camber setting, yes MM plates are a good choice, but if you're trying to get a lot of camber to tuck obscenely large tires under the fenders, MM plates may leave you high and dry. Steedas work tho.
Anyway, its unclear if the OP needs camber plates, because his GT350 fenders are wider.
tj@steeda
Timothy
= Smiles for days
The Steeda plates are a great choice - most adjustment range on the market: adjust camber angle from -0.3 degrees to -2.8 degrees!
Johnnyracer222
Lynn, MA
Johnny
2015 Mustang GTPP 6 speed
Oh, you're in Boston/North Shore, like me?
Ya, get an F150....these pot holes will swallow our entire Mustang...
