Stupid question re Defoulers
robvas
MI
2011 GT
I have direct experience with 2 cars with the 10% issue and 2 more have reported here.
It's very possible that other thread isn't completely accurate.
How often do you see cars with defoulers run without issue?
Does it happen without defoulers? Does it make more sense to just live with the light than try to avoid it?
KBR Stang
Central NY
Allan
2021 Mach 1 on order, 2011 Mustang GT
I believe what I see rather than what Im told. I ran the anti foulers with GESI UHO cats. Within three or 4 drive cycles I could see the LTFT going richer. When it hit 12% I reset it. Same thing happened again. Start out fine and then goes out of wack not to.mention the heater and o2 sensors wont set.
At the time I was able to turn off FAOSC, the rear O2 sensors, fault codes, and heaters. I drove the car a month and the LTFT stayed at 3% rich. When I put everything back to stock and turned everything back on, same results. Sits at 3%, stay 0 to 1%. There is something to it.
That's what I've been worrying about. I don't want to spend $1300 on GESI Gen 2 UHO just to have the same issue...ugh.
junits15
MA
Justin
2019 Mustang GT
Unfortunately the only cats that will guarantee no check engine light without defoulers or disabling P0420/P0430 are factory cats.
And GT cats are not going to last under boost.
Robottrainer
Canada
2018 Ford Escape. 2020 Jeep Cherokee. 2021 Ford Mustang GT Stage 2 Roush
Mine are sitting in my basement in case one day It's my only option.
