STOP Buying TPMS Training Tool for 2015+
RubyRed15
Ok, so it's blue.
CO
Ecoboost Premium PP
Speaking of TPMS... if a set of tires is mounted and balanced, and then you add TPMS sensors, will they need to be rebalanced?
JB1
Houston
2016 Mustang V6
I put a set of staggered 19" PP take offs on my 2016 and after a few miles the TPMS synced to the car and all is fine,just as stated no tool required.
Thanks for this thread
jvandy50
H3249
AR
jason
23 Bronco, 18 ZL1-1LE
i ended up going through 3 sets, yes 3, tpms sensors before my car, the tool, and the sensors decided to play nice.
they are not oem sensors, so maybe that's what it is. but i definitely needed the tool.
18psi
of boost
Best Coast
Bringing up this thread just to ask a follow up: does it have to be exactly 25 miles? Or can take up to 25 miles for it to "learn"?
I swapped on a set of 2016 oem wheels with tpms sensors onto my 15 the other day, it's been at least 10-15 miles and still nothing. Just curious
DRKHORS
Mark
'18 F150, '23 Mustang GT
Results will vary. Some have them relearn very quickly while some do not. When I went to aftermarket tires/wheels mine took right at 25 miles to relearn.
Terminated
GTFO_0009
MA
Marcus
Bagged & Boosted 50th Anniversary
Might have missed it, but what sensors are you using? If they're Oro-Tek, then I completely understand the issues. Biggest POS sensors I've ever had the displeasure of using. [MENTION=13665]V8Venom[/MENTION] can attest to this.
ForTehNguyen
Houston, Texas
15 GT
just buy OEM sensors can get a full OEM set for under $80 on ebay, set it and forget it.
I had TPMS replaced on our 06 IS350. They pulled the tire bead down to expose the sensor to change it but never dismounted the tire, so it never needed to be rebalanced
V8Venom
700 Club
SoCal
2020 Shelby GT500
Yup those sensors are pure trash! Haven't worked in my car since I put them on and yet American Muscle keeps sending them to me to replace. Umm...no thanks.
vogtaction
St Louis
Sean
2015 premium ecoboost auto mustang
If you get new sensors and they arent your old ones they will not program to the car without a tool. I bought some factory ones off a guy on ebay for my aftermarket wheels and drove 2 months with the light on. Tried to start the learning process and do the "let the air out trick" of each tire but still didnt work. I ended up going up to the local dealership and they did it on the spot for free.
Enoch
UK
Andy
Guard 5.0 (Auto) Fastback, Saddle Leather
I have 2 sets of wheels....my originals, and some P6G.... both sets are fitted with genuine ford sensors.:)
I've swapped the wheels over a number of times, and they've synced with the TPMS every single time.
All I did was swap the wheels, press reset in the menu, and go for a drive... within a mile or so the new sensors are reading fine:thumbsup:
18psi
of boost
Best Coast
Where do you press reset in the menu?
Enoch
UK
Andy
berserker_sid
MILL CREEK-WA
2016 Guard GT premium
totally agreed.. just recently changed my wheels and tires.. and the tire light came for like 5 minutes and then it was gone
jvandy50
H3249
AR
jason
First 2 sets were oro-tek, yes. Third set was a different brand and worked. OEM might work without a tool, but aftermarket is hit or miss...so this thread title is a little misleading.
