Steeda Tie Rod Ends
tj@steeda
Timothy
Let me run this by our tech team - i'll provide you with feedback once I hear back.
Thank you!
TJ
WItoTX
Houston
Kyle
'17 GT350
What did you mean by this?
My bad. Yes, they are tie rods ends. And yes, if you are getting this fancy part, might as well fix the bump steer while you are at it. At least I understood your post to say you didn't want to correct the bump steer, but maybe what you are saying is it doesn't have bump steer?
tj@steeda
Timothy
I thought I read somewhere, and is it correct, that aside from bumpsteer (that I’m not trying to correct), these can be used as just a stock replacement tie rod end upgrade? Are they worth it? They’re nice!
https://www.steeda.com/steeda-555-8134-shelby-gt350-bumpsteer-kit
You are correct, they can fix bump steer or replace worn-out tie rod ends with high-quality, billet aluminum adjusters, Teflon lined rod ends, and billet chromoly studs.
Install with confidence!
Best Regards,
TJ
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
1MeanZ
Indiana
Jeremy
2016 Mustang GT PP M6 1986 Camaro IROC-Z
What is the life expectancy of these on the street?
I've got 31K miles on my Steeda tie rod ends (i did the bump steer correction) and they are still tight as new. I keep a close eye on them because I expected them to not last long on the street but they are still just fine. Car runs March through end of October in the midwest but sees rain only a couple times per year.
galaxy
St Louis
'17 GT350
Thanks man! So…I don’t know that I have bumpsteer. Car drives amazing and is a joy to drive. Car is lowered, so I’m assuming the argument would be yes, yes I do…whether I know it or not, LOL.
Car needs rod ends anyways, so I was looking at these for a quality/cool replacement more so than to address bumpsteer. At least for the time being or wiling to tackle.
I’m curious about life expectancy of the fancy spherical ends also, as it seems sometimes those don’t fare so well in the long term. Especially if exposed to normal elements.
WItoTX
Houston
Kyle
'17 GT350
What springs do you have? When I had the FP springs, I had bump steer. If I looked at the geometry of the front, it wasn't obvious, but when my PS failed, it was very evident on track day that there was bump steer issues.
I can't speak to longevity, my car only gets driven to and from events. And if it's further than a 45 min drive, I trailer it. Hopefully someone who has used it on a daily can give you a better answer on that.
But quality wise, I have seen them on multiple cars, and they are solid for sure.
galaxy
St Louis
'17 GT350
@WItoTX ssshhhhh…it’s for my 197 car. Keep that on the DL. Thus my question about the part was more a generic one! But since we’re here, it also has FP K springs. It’s a healthy drop.
As far as looks, what are you eyeballing? Been reading up on it, and the goal is to have the toe arm parallel with the lower control arm, or there abouts? That’ll get you way in the ballgame?
WItoTX
Houston
Kyle
'17 GT350
Yes, that is what I was looking at. If you have access, get it on a lift. Then lift the car up, and see how much the toe changes. Depending on how it changes, adjust the tie rod ends.
Bluemustang
2015 Mustang Base GT
If you lowered the car you've introduced some bumpsteer into it. Tie rod ends are a maintenance items anyway so if it were me, I'd just buy the adjustable "bumpsteer" tie rod ends and you can kill two birds with one stone. J&M makes a nice set that I currently use. The easy way to adjust them is to adjust the length of the tie rod with the spacers so that it's parallel to the control arms. That should get the bumpsteer close enough and chances are your car will handle a little better too.
galaxy
St Louis
'17 GT350
How well does this style end hold up? Guessing weather and/or all driving conditions may be harder on them than typical ends? Shorter lifespan? But…racecar!!
