Steeda jacking rails on my Vert!!!!
88lx50
NYC
2018 Mustang GT convertible 6 speed
I have them on a vert as well. I did not notice any difference over bumps and corners. But the car is fairly solid already so I did not think I would notice any additional stiffness.
Fordever
Fordever
NL, Canada
Derek
2016 GT/CS Convertible
What's the best way to raise the vehicle enough to allow one to install the Steeda jacking rails? Or can they be installed without raising the vehicle?
I am lowered with BMR and still had enough room the install without jacking anything. Rachet and a socket and all good:headbang:
Besides the primary advantage, have you noticed any difference in bumps, corners, etc?
CVCashmere
I really haven’t noticed any difference. I have probably only put a 100 miles on the car since. Most has been spirited driving and haven’t felt any real difference :shrug:
BluePonyGT
Seattle, WA
Corey
2017 Grabber Blue GT Premium 6MT
Get a good set of ramps. I did mine with just the front up on ramps. The issue here is you have to remove some of the seam sealer, and that's just easier if you can see what you're doing. With the car on the ground it's a bit harder to do, so unless you have a scraper doing it with a razor blade may require you buy stock in Johnson & Johnson for band-aids.
Fordever
Fordever
NL, Canada
Derek
If you look at my pics in the original post, you will see some seam sealer on the floor. I just used a sharp chisel and took my time. I was feeling as I went along the seam and slowly chiseled it away. It worked for me, but no doubt it would be easier if you can see what you are doing. :D
Redcruzer
Redwood City
2015 eco boost premium convertible, Ruby red
I used a chisel also. Piece of cake.
tj@steeda
Timothy
Great feedback & always good to see the community working together!
saltydogg
NC
2018 GT Premium convertible - 401A, 6MT
Is it possible to remove the factory monster subframe braces with these installed and supporting the car? If not, does anyone know if the subframe can be lowered enough to install springs with the factory subframe brace installed (I’m thinking not). All the videos online are fastbacks without the vert brace.
Synar
Quebec , Canada
Sylvain
2017 GT Premium PP Convertible Platinum White
Hi Steve ,
You can't, you have to remove the jack rail and also the braces to lower the suspension enough, just did mine and no other way to do it.
Cheers,
88lx50
NYC
You have to remove the factory braces to lower suspension, but you can remove the rear bolts and loosen the front bolts on the jacking rails to remove the factory braces. You don't need to completely remove them.
