Steeda clutch perch and spring
gixxersixxerman
Las Vegas
Thomas
2020 GR Supra
This is soooo entertaining hahahaha
Gloucesternige
UK
'17 Mustang GT, GR Yaris, SWB Defender, Harley.
I believe the stock spring is "helping" you push the pedal, thereby giving less feel, much like an over servo'd braking system.
The lighter spring helps less, which equals a heavier pedal and more feel.
I have the spring, but haven't fitted it yet.
W111BOB
Doncaster, UK
Bob
Mustang GT 5.0 ORANGUSTANG
from the Steeda website ...
The combination of a high-rate assist spring and motion of the pedal during engagement causes a non-linear and sometimes confusing pedal feel. Having a non-linear pedal feel makes it hard to modulate the clutch on your Mustang GT or EcoBoost
Many new Mustang owners have found that taking out the stock OE spring will give you somewhat similar results, but realistically the clutch becomes far too heavy especially if your Mustang is daily driven.
Most owners fail to realize the prolonged effects of simply taking out your factory OE spring and not replacing it with another spring.
By negating your factory clutch assist spring you will notice chatter/NVH from your clutch pedal. Your clutch pedal will never fully return to stock position without any assist spring, and over time your slave cylinder may begin leaking due to constant pressure on its seals from the clutch pedal not returning to the stock position. Avoid these problems in the future by installing our Steeda S550 Mustang Clutch Assist Spring 35 lb/in into your GT, EcoBoost or V6.
So its an "assist" spring- it is lighter - and makes pedal movement easier - and with more feeling - whilst ensuring the pedal returns properly...
Personally - First time I drove having changed it - I felt no difference... but a few tens of miles later - I "get it"- easier and with more feeling... it certainly isnt harder or heavier - how could it be?:confused:
This thread is fun! :D:D
Gloucesternige
UK
I think the first line says it all. “High rate ASSIST spring”
Still I can’t really argue because I haven’t fitted mine yet. Thinking about it, doesn’t the spring assist by helping the pedal go over a fulcrum, therefore holding the pedal in the up position but once the fulcrum point is reached it ops pressure the other way?
Wolvee
Williamsburg
2021 Shelby GT500
The argument is that the Stock 185lb spring makes the pedal to light and vague. The 35lb spring being much lighter makes the pedal stiffer because of the pressure of the Clutch itself. The force of pressing in the clutch isn't 185 or 35 pounds, it's more than that. The pressure of the clutch is what makes the pedal stiff.
The stock 185lb spring counteracts the stiff Clutch and by many performance orientated drivers makes the clutch Too light. The 35lb Clutch spring allows you to feel the actual clutch engagement weight better by having less resistance. Lighter spring, heavier feel.
W111BOB
Doncaster, UK
Bob
brilliant!! totally wrong - but brilliant reply - :clap2:
you feeling better now?
and.... relaxxxxxx...
Cheers
Bob
tj@steeda
Timothy
Check out this video by CJ Pony Parts, it should answer it for you & give you the ins & outs of the Steeda clutch assist.
[ame="https://vimeo.com/244873480"]https://vimeo.com/244873480[/ame]
W111BOB
Doncaster, UK
Bob
I know steeda would rescue the thread!6
tj@steeda
Timothy
The best way I can an explain it in a non-technical way is ... it requires more effort from the driver but actually allows you to feel the engagement easier.
Your shifts will be smoother with the new spring!
TJ
W111BOB
Doncaster, UK
Bob
TJ
So we are ALL right!
Great... and good reply!
No offence to anyone involved... it was fun!
Big_G
Sunderland, UK
2017 GT Fastback
TJ
Opposite for me now, with my 2015 Ecoboost the clutch/gear changes were awful and judderly especially going 1st to 2nd. I put the Steeda spring & perch and it it was totally different, smooth & easy.
I pulled the Steeda spring and perch out when i sold it a couple of weeks ago and was going to put it into my 2017 GT ... however the clutch pedal feels completely different in the GT, its normal, there's no issues with any gear change :shrug:
W111BOB
Doncaster, UK
Bob
"I feel like I'm playing cards with my sisters kids."
"you gonna do something - or just stand there and bleed?"
BTW - it is "brothers kids" not sisters... - and the guy that said it was a loser :D
Manders Mustang
The Boss
Birmingham - United Kingdom
2016 Race Red Ecoboost
[MENTION=34119]W111BOB[/MENTION] / [MENTION=32969]Wolvee[/MENTION] come on now, don't missquote Tombstone ;)!
"its like I'm sitting here playing cards with my brother's kids or something - you nerve wrecking sons a bitches"
W111BOB
Doncaster, UK
Bob
And 2 minutes later.."you gonna do something...or just stand there and bleed"
No misquote from me!!
