The Steeda Clutch spring
hinch
uk
Sideways
So... someone ELI5 this for me; does the spring reduce effort, or increase it? (on my leg). The clutch on mine is fine; easy to use, no crunching etc. It's FAR better than the demo car I tested in February. It's similar to the Monaro - and miles better than some of the older cars I've owned.
I'm the same I love the standard clutch and have no issues what so ever I think the people that are noticing the issue more are people coming from more normal/sedate cars those used to horribly engineered beasts (why hello ford tolerances) have no issue with it.
willisit
Denmead, UK
Mustang, Monaro, DeLorean, Viva, S5, 600F
Thanks both; I'll stick with stock for now. I can see why, at ÂŁ20, it's a no brainer.. but it wasn't a brainer to begin with for me. I like the effort - I wouldn't want it any lighter, and coming from the Viva (breathe and it's on the floor) or DeLorean (fire a cannon at it to move it) it's kinda nice :p
Manders Mustang
The Boss
Birmingham - United Kingdom
2016 Race Red Ecoboost
Wait. some people think the stock spring is too heavy, am I missing something because I feel like mine isn't even there :lol:
Steeda UK
London, UK
www.steeda.co.uk
Mustangs
Its not the overall feel of the clutch as far as I've been told, its the transition through the centre that can feel "oversprung" from the factory, meaning jerky clutch control rather than a smooth release. But either way, if you are happy with stock, and have no issues, then there is no need to change anything!
Manders Mustang
The Boss
Ah well now you mention it, you can't really tell at times, but I'm fine with it, but I'm sure when I need to scratch the itch of modding i'll end up with yours ;)!
SteveS
...Bon Scott Land...
Bon Scott Land
Mustang GT Magnetic
Hi [MENTION=21524]willisit[/MENTION] the spring makes controlling the clutch pedal easier as it makes the transitions easier to cope with, being a lighter spring rate.
Some people (generally who are used to the type of car / clutch) have no real issues, and dont see that much difference with the Steeda spring, other people swear by it. Either way for less than ÂŁ20 its a 'no lose' option for manual drivers.
I'm correct in thinking it makes the clutch heavier though, ie it requires more effort on the drivers part therefore giving more feel?
Also, as I remember it where the "no lose" becomes a "lose" is if you were to want to re-fit the stock spring; that job being a b@stard and no mistake? Not that I can recall ever hearing of anyone wanting to do that.
Steeda UK
London, UK
www.steeda.co.uk
Mustangs
[MENTION=14613]SteveS[/MENTION] the stock clutch spring is 185 lb/in rated whereas the Steeda one is 35 lb/in so a lot lighter. As i mentioned above, the idea is to stop the powerful stock spring "snapping up" the pedal in mid transition resulting in an effective 'clutch kick'.
Fitting should be a simple & quick job as long as care is taken, and the same to swap back should you wish to do so, as far as I know, not that I have ever heard of anyone swapping back as you say.
Jimboy2
Denmead, Waterlooville
Mazda Mx5 :(
If you want to feel the difference in clutch feel give me a shout. I have replaced the spring
willisit
Denmead, UK
w0rt3x
Melbourne VIC
MY17 GT Fastback Manual Ruby Red
I installed it yesterday and definitely improved the feel and the engagement with the transmission. Though, when the pedal is all the way up, there is a bit of a play. The pedal travels up and down for a few millimeters before I start feeling resistance. Is this normal? Anyone else experiencing the same thing?
