Sasuketr
- Aug 16, 2014
- Chicago,IL
- 2015 Ingot Silver GTPP
David,Hey, I'm sure you're aware that many factors come into play when running your car at the track. If you wanted to do an apples to apples comparison, you should run both the stock intake and an aftermarket CAI the same day with consistent engine temps and IAT for the runs.
Does using factory screws for MAF housing cause any problems? They were taller than the ones you guys provided! My worry is that if the bolt holes go all the way to the inner diameter of the retrictor, then the bolts will disturb the flow!
