Slip on spacer
Ewheels
SoCal
Eric
'18 GT PP1, '23 F150, '24 4Runner Pro
a +50 is already out 2mm from an APEX wheel, a 23mm spacer would be ideal.
Can confirm this.
I have +25mm spacers on +50 offset wheels and I rub the outer edge of the front tire against the top of the fender. This is with -3° camber.
Redfuzzbutt
Redfuzzbutt
Northern AZ
'17 Mustang GT
Can confirm this.
You running a 305 or something bigger? How low are you in the front?
Already purchased the Apex +25mm spacers and the wheel liners aren't a big priority/issue. Wait, you running fender or wheel liner?
Ewheels
SoCal
Eric
305 square tires and maybe 0.75" lower than stock in front.
It's not the rubbing to the fender/wheel liner that concerns me. It's the rubbing on the tire that wears them prematurely that is concerning. Tires are expensive as-is; I don't want to replace them any faster than I already do.
EDIT: granted this rubbing only occurs on track under max compression situations. Regular street driving causes no rubbing.
