tosha
This topic is always causing a lot of debate over something that has a number of benefits with no downsides. To name a few:I am always curious why you can't just buy wheels with the correct offset. Do the wheel manufacturers only make a wheel to fit the rear or front? Honest question, not trying to be a smart ass.
1) ability to rotate tires front-back without taking them off the rims
2) what OP mentioned regarding tire damage and chassis tuning
3) as soon as you set proper track camber up front, your stock 255 wheels will look terribly tucked into the fenders. 25mm spacers will fix that perfectly
4) if you have PP1, you can buy two 10in replica PP1 wheels from American Muscle dirt cheap, and have proper rotatable and square wheel setup for street.
5) You never need to take the spacer off for all of that.
6) it helps same lots of money in long run
Just get proper spacers and studs from Tim OPMustang, install them once and enjoy a ton more flexibility with the wheels and tires choices. If you don't want to drive with spacers all the time, just take them off, but I am pretty sure you won't want to.
All of it is irrelevant if you don't plan to go beyond 285 tire size.
