Spacer thickness help - 18x10 with 305s
higdominator
Central Oklahoma
2016 GT PPP
The wheel wouldn't fit over the brake caliper? It's the GTPP caliper, right? That's strange.
higdominator
Central Oklahoma
2016 GT PPP
I totally forgot to get that for you, my bad. I'm making an alert on my phone to measure them as soon as I get home this afternoon. The wheels are literally 3 FT from my car. ;)
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
I'd take a gander at 10 mm clearing, just. 15 will be safe. Obviously you need the longer studs.
Competition Orange
Columbus, Ohio
2017 GT350
I ordered 15mm from Tim at OPMustang, should be here tomorrow. More to come, might test fit with my 2, 5mm stacked tonight.
Competition Orange
Columbus, Ohio
2017 GT350
Bumping this.
I'm trying to decide if I should stick with the 305 680 18 or try the 295 680 18 dh. Amazingly, the 295 is 0.2" taller at 27.1 vs 26.9 but maybe more importantly is 0.6" narrower on both tread width (10.8 vs 11.4) and section width (11.4 vs 12.0).
Thoughts on which would have less fender arch rubbing? I'm going to try [MENTION=20846]ddozier[/MENTION] fender spacer technique and I've added konis and steeda sways so I think I'd be fine with the 305s still, but want to place my order soon ;)
NightmareMoon
2016 Mustang GT PP w/ Voodoo
If you're running camber bolts, you're going to have less clearance than the typical guy running 305s on a 10" wheel. YMMV.
Competition Orange
Columbus, Ohio
2017 GT350
I'm not running into strut clearance, I'm running into fender arch, or outer (inner portion) fender rub. More camber will only HELP that.
