Slight miss at Idle.
Daryl333
Vancouver Canada
Daryl
2017 Mustang GT
2017 Mustang GT
25,000 Miles. 6R80
Whipple Gen 3
ID 1050 Inj. been professionally inspected
New NGK 6510 Plugs .028".
No codes.
Can feel miss in my seat and see in the puffs in exhaust stream.
Can see minor fluctuations on tach and vacuum gauge.
Install has been inspected with smoke,Propane and visual twice. Tuner says logs are fine.
Have a short video.
Is this my OCD or is something amiss here?
Thx.
Proshop
Billy
2021 Ford Mustang GT
Any fuel mods other than the 1050’s? Looks pretty normal to me but my car behaves like a race car most of the time so.. 🤣
HKusp
Hampton, Md.
Jason
I don't see anything out of the ordinary from my experience. Engines have a little bit of fluctuation from time to time during idle. I don't doubt that you are sensing something different than you are used to if this is a new install, things are going to be different from when it was stock because the tuning is different.
Daryl333
Daryl333
Vancouver Canada
Daryl
2017 Mustang GT
VMP Fuel Boosta Pump.
I've been told the Whipple 132 TB causes this slight fluctuation. But being able to feel it in my seat bothers me...
Lol
Daryl333
Daryl333
Vancouver Canada
Daryl
2017 Mustang GT
My 3V cars had a 2.3 Roush and a 2.3 Whipple and never felt this miss. But people are saying live with it but...
Lol
Is the vacuum gauge supposed to fluctuate like this?
Thx
BlackandBlue
Mustang
Larger injectors lose resolution since they are moving more fuel and the pulse width is lower than smaller injectors. At high Rpm/load it is the same but not at idle.
They will be less precise so a random miss at idle comes with the territory.
HKusp
Hampton, Md.
Jason
Again, I am not saying you are crazy. We know our cars and you obviously have significant experience with forced induction cars. One thing I would do is plumb in a mechanical boost/vacuum gauge and see if it is mirroring the electronic gauge you are seeing on the dash. That one the car is using , obviously is electrical and uses data from sensors and the PCM infers boost/vacuum from input it receives and uses an algorithm. Some of that input is now changed based off of tuning so that may account for some if not all, of the fluctuation you are seeing.
Daryl333
Daryl333
Vancouver Canada
Daryl
2017 Mustang GT
Well I didn't use a mechanical but installed an AEM Digital Boost/Vacuum gauge coming off a port in the Whipple Manifold.
Dash gauge reads 18.5 AEM Gauge reads 20.
Have a dyno appt on the 10th to get a WOT log so haven't gone into boost yet.
What concerns me is my tuner thinks that the Whipple 132 Throttle Body Angle is causing the slight stumble at idle. And that he can't do anything about it.
Wouldn't all cars with Whipple TBs be fluctuating at idle? Lol Or is it time to be looking for a new guy.
Daryl333
Daryl333
Vancouver Canada
Daryl
2017 Mustang GT
Okay sort of what my tuner said. But he said it was due to Throttle body angle of the Whipple 132 TB and there's nothing he can do about it.
So after hearing you it's starting to make sense.
HKusp
Hampton, Md.
Jason
I know a lot of Tuners had difficulty with the early Whipple 132's. I don't know if Whipple changed them, or if people eventually got a better handle on them, but it's not as big of a problem now as it has been in the past.
Daryl333
Daryl333
Vancouver Canada
Daryl
2017 Mustang GT
I contacted a four letter tuning company and they said they have no troubles tuning tuning the Whipple TB. But $800 is a lot to spend for an idle fluctuation.
We'll see I guess, thx for the feedback.
Daryl333
Daryl333
Vancouver Canada
Daryl
2017 Mustang GT
Li Tuning Return style system
Granthenneke
Waco
Grant
Was there ever a solution to this? My car has the Gen 6 whipple with the 132 and it has a light miss at idle too. And it’s not all the time. It’s intermittent and you can feel it in the seat. GT500 injectors with a BAP
HKusp
Hampton, Md.
Jason
Maybe @engineermike can shed some light on the subject. He "dabbles" in tuning and has several experiences with the 132mm TB that the stage 2 Whipples use.
engineermike
La
2018 GTPP A10
Couple of things come to mind...
On the id1050 injectors, they should work just fine as long as a) they are being run above their minimum pulsewidth and b) the tuning data is correct. When I see sai li fuel system, a pitfall immediately comes to mind. Some tuners think since the return-style systems "attempt" to hold constant pressure then they should use the constant pressure fuel injector data, which is the wrong answer, so hopefully they got that part right.
On the GT500 injectors, are we talking Trinity or Predator version? Greg Banish had some pretty harsh things to say about the Predator version and the factory variability from injector to injector, so that could contribute.
On the big TB, the way idle is controlled on these is very non-intuitive. The logic calculates how much torque it takes to run the engine at idle, including accessories, rotating friction, pumping losses (both intake and exhaust), and torque converter if an auto in gear. It then adds a specified torque margin (they call it "reserve"). The torque-to-load tables are used to convert this torque to a cylinder air load, which is then converted to air flow. The throttle is opened enough to achieve this air flow, but that opened amount is dependent also on the TB model and the SD model, both of which aren't super-accurate from Whipple (none of them are as accurate as stock). But there is a feedback PID mass airflow control loop, so if there is error the TB is allowed some limited amount of correction. It's possible you're seeing this correction loop at play. Anyway, if you are still following, the torque request is more than what's needed due to the reserve amount, so it has excess airflow to sustain idle. The idle is then controlled by pulling the timing down and it has its own torque-based PID feedback control loop...so you can see where the MBT tables also need to be accurate for idle to be OEM-like.
So, for the aftermarket to get stock-like idle quality, you can see that the injector data, torque model, pumping loss model, throttle body model, speed density model, and MBT timing model all have to be accurate. And Ford spent millions on this with small armies of calibrators, which aftermarket companies can't afford.
