slight clunk when shifting
nannerpuddin
greenville,sc
nanner
2019 mustang gt
is it normal to hear a slight clunk when shifting from first to second? does it more if i dont completely let off throttle before shifting. 2019-manual-30k miles.just got the car im still learning all her qwerks
Unbridled5.0
NTX
2022 5.0 N/A, 2004 Mach 1 SC'd
My guess would be gear backlash in the rear. Mine has done it since new and can happen in just about any gear if you hit the clutch 'wrong'.
Used to have an IRS in my 04 Mach 1 that did it also. It was a common thing on the Terminators. My friends 04 Cobra does it. If that's what it is, you'll learn how to drive around it to minimize it.
Get under the car with it safely on a lift or Jack stands and check the driveshaft center support bearing (also known as a guibo)…. See this thread:
https://www.mustang6g.com/forums/th...-no-idea-how-close-i-was.227567/#post-4473723
It’s a common wear point on the S550, some are worse than others.
Clover
Mountains
Factory 5 1965 Shelby Daytona Replica in progress, , 2021 Ford Mustang Mach 1
When I first started driving my Mach 1, I was fairly unsmooth on my 1/2 shift and would upset the car by shifting too fast. The gap in gearing between 1st and second is fairly large and you need to wait a beat before going from one to two to allow the revs to fall enough. Maybe a completely separate issue, but try giving a bit of extra time to the one two shift to make sure you are giving enough time for the revs to drop to where you need them for 2nd gear.
Aramis
SE US
Mik
2016 GT Ragtop
Is it just sound or do you also feel it in the shifter? That would narrow it down I suspect
