Rotating tires side to side
rcald
Randy
20 GT 350, 20 Bullitt, 02 GT Vert, 07 Stage 3 Roush, 12 Boss 302, 03 Mach 1
Any thoughts on rotating the tires from side to side? Ford service is stating not needed. At 11,800 miles there are no visual wear issues seen.
dirtwarrior
kentucky
Joe
2015 3.7 mustang
If they are the same size rotate as usual. If larger size on back then side to side
rcald
rcald
Randy
2020 Mustang Bullitt
FRONT 255/40 R 19
BACK 275/40 R 19
POJ 1
Auckland New Zealand
Phil
2019 Bullitt build no.301
I endorse it
Norm Peterson
corner barstool sitter
Norm
'08 GT #85, '19 WRX
Can't hurt unless like said above the tires are directional.
If they have "OUTSIDE" embossed in the sidewall without any directional arrows, go ahead and rotate them side to side.
Norm
rcald
rcald
Randy
Thanks guys, outside with no arrows is confirmed.
OldPhart
Rochester, NY area
Bruce
‘05 GMC P/U, ‘17 Impala, 19 Bullitt
Hi - I rotated mine (all 4 side to side) at around 8000 miles this spring and shortly afterwards I noticed an increase in the level of road noise. My wife noticed it too. All tires appear evenly worn and the ride is smooth even at high speeds so it shouldn't be a balance or alignment issue. I can't explain it, but it has gotten annoying enough that I may try rotating them back to their original placement to see if it goes away. The tires show minimal wear so I'm not really wanting to replace them, but it's bugging me. It's apparent with the windows open or closed. I play music now pretty regularly to help disguise the noise. I keep my exhaust set on normal so I don't really hear the noise until I stop accelerating. I'm at 11,000 miles now and no change In noise level. The exhaust noise is minimal when cruising at an even speed and that's when I hear it... Bruce
Norm Peterson
Norm
'08 GT #85, '19 WRX
Unless you know what your car's alignment settings actually are, they could be (and probably are) slightly different, side to side, which would tend to cause slightly different wear patterns below what you might be able to notice by eye.
Norm
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
This wear can cause noise.
I'm biased from the 70's when changing the rotational direction of radials was a no no. I still will not rotate a radial side to side.
Front to back same side of car only.
OldPhart
Rochester, NY area
Bruce
FOLLOW-UP: I had the tires rotated back to their original positions where they were for the first 7,930 miles. The tires were rebalanced which was minimal (1/2 oz or less) and milage was 11,230 with the same tire pressures. I examined the tires when the were removed and the tire guy agreed that all 4 tires were evenly worn and he said they have a good amount of tread left for the milage. At age 80, I drive conservatively (well, most of the time). I drove to and from the rotation at the same highway speed of 60 mph. I understand this a subjective evaluation, but I sensed a noise reduction of at least 50%. So, for what it's worth (probably not a lot) that is my experience. This suggests to me that if the car is properly aligned, just rebalance the tires occasionally and don't rotate them side to side when front and back tires are a different size. It's possible that a different brand might respond differently. If you end up someday with unidirectional tires where front and back are different sizes, you can't rotate them anyway... Bruce
  • Like
Reactions: 12g
bryyce62
NorCal
G dub
2020 GT PP2
What Dan (K4fxd) said...
cerbomark
TN
20 GT PP2. 21 Mach1 (Sold)
Sport/summer tires generally get louder as they wear. I have seen this numerous times.
If you say they are wearing perfect then that s it. Some brands worse than others.
Norm Peterson
Norm
'08 GT #85, '19 WRX
Ah yes . . . the era of the first tire fiasco involving Firestone. Remember of it well (a cousin of mine had 4 tires that were involved).
Norm
