Requesting suspension setup assessment
Bull Run
AZ
2015 Mustang EB Prem PP
I'm wondering if I need more dampening than what's provided by Pro-Action fixed dampers since the car feels bouncier with the latest suspension modes. To be fair, Steeda's guide recommends Pro-Action adjustable dampers for Ultralite Linear Springs and replacing many of the soft bushings with spherical bearings further firmed up the ride. I plan on upgrading tires to something stickier once the current set is worn out.
Video below shows a slightly sharper than 90 degree left turn onto a highway ramp at around 45 MPH. Unfortunately, I wasn't able to gun it after the turn because there was cars head on the ramp. I was doing about 75 MPH by end of the video.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Bumpstops, are they cut? How much?
Tire size and pressures?
Do you have Steeda's billet shock mounts?
SteedaTech
Pompano Beach, FL
2016 Mustang Q750
pm your current build list and contact info. I will go over your build with you.
Thank you,
Mike D
Norm Peterson
corner barstool sitter
Norm
'08 GT #85, '19 WRX
Pretty sure I'm seeing some early-apexing - heading toward the left-side and getting there too soon, where you then have to add some steering well past the apex to stay in your lane. This is likely to create more roll late in the turn, which means the suspension motion then will be opposite to what you expect as you exit the corner.
There might have been some pavement unevenness right at the beginning of the ramp, but I'm not seeing enough resolution in that part of the video to be sure.
What's that chime going off for?
Norm
Bull Run
Bull Run
AZ
Norm
Perhaps because I turned like in a typical 90 degree left turn on a major street. But since it's a highway ramp, it cuts in more to merge with the highway and that's where I gave it additional steering. I'll do some drive mod in when taking this ramp the next time for a smoother steering.
Chime is from the dashcam as it has lane keeping and collision alarms built in.
Bull Run
Bull Run
AZ
The following are my handling mods:
Wheels and Tires
Advanti DST HY Hybris (19x9.5 square)
Sumitomo HTR Z III XL 285ZR19s (front)
Continental ExtremeContact Sport SL 285ZR19s (rear)
Chassis and Suspension
BMR Cradle Bushing Lockout Kit
BMR Vertical Links with spherical bearings
Steeda Strut Tower Brace
Steeda Extreme G-Trac K-Member Brace
Steeda Pro Action fixed shocks and struts
Steeda Billet Rear Shock Mounts
GT350R Front Sway Bar
GT350R Rear Sway Bar
Steeda Ultralite Sport Springs Linear
Steeda Front Camber Plates
Steeda Aluminum Differential Mount Busing System
Steeda Alignment Kit for BMR CB005
Steeda Rear Adjustable Camber Arms
Steeda Bump Steer Correction Kit
Steeda Front Control Arm Lateral Links w/ Extended Ball Joint
Steeda Toe Links and Bearing Assembly
Steeda Front Control Arm Tension Links with Spherical Bearings
Steeda Rear Control Arm Spherical Bearings
Advanti wheels weigh about 20 lbs each and I did additional weight loss mods, such as EradiSpeed rotors, CF DS, and balance shaft delete.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
I'm guessing that's it right there.
BmacIL
Enginerd
Naperville, IL
You probably at least need rear adjustables. The front is definitely better controlled by the fixed valve pro actions than the rear, from my experience.
SteedaTech
Pompano Beach, FL
2016 Mustang Q750
Thanks, I may try that first since swapping rear shocks is much easier than front struts.
For a better ride quality and for road race applications the Steeda urethane billet vertical links are the ticket.
Steeda Tech
Bull Run
Bull Run
AZ
Spoke with Mike. He thinks that Pro-action fixed should be good enough for my setup and suggested trying polyurethane billet vertical links, as they are more road race focused than the spherical bearing vertical links currently on the car. They have been ordered and will report back once installed.
tj@steeda
Timothy
You are in good hands, Bull Run - look forward to the feedback!
Tj
