Re-Calibrating Speedometer/ Different Tire Size
svtfever
ALEX
TX
William
2019 GTPP1
So I have a non-HP car and want to add HP wheels and similar tire size but the sizes are significantly off from the 255-40-19 and 275-40-19s if I go HP sizing. How can I go about fixing this. If it were off 1-2 mph I would not worry about it but if its off 4-6 mph can this be adjusted? Thanks!
m3incorp
Georgia/Colorado
James
Yes, you can adjust yourself using ForScan or a dealer can adjust it. Unfortunately, the dealer tried to adjust mine from reading 2 mph too slow and after the adjustment, it reads 5 mph too low. Good thing I wasn't charged for it. I have a ForScan device but just need to take the time to do it.
Seanuf99
St Louis Area
Sean
2021 Mustang GT
I used the Pro Cal tool to change my tire RM when I switched from the stock 235/50/18 to 275/40/18. I used the RM spec provided by Continental. At varying highway speeds the speedometer is consistently 2mph slower than what Google Maps is showing on my phone. I am going to try it later with my Wahoo bike computer to see if it lines up. Anyone have any tips for validating the speedometer calibration is correct? I mean without setting cruise control for 20mph over and then asking the State Trooper what he clocked you at? I mean that would work, but would be an expensive option.
m3incorp
Georgia/Colorado
James
I use my radar detector with gps and my phone to validate. They are very close to the speedometer in my other vehicles and show the Mustang speedometer to be reading 5 mph slower than actual speed.
Seanuf99
St Louis Area
Sean
2021 Mustang GT
Good idea. I should have compared the phone/bike computer (no radar detector) prior to swapping the wheels, but did not give it a thought. I will compare them in my wife's car today, see what the differences are, then try in the Mustang at same speeds.
Epiphany
Global
I like to disassemble things.
Can you use the Procal for anything else?
Seanuf99
St Louis Area
Sean
2021 Mustang GT
Hey,
So I got the procal tool as part of the GT Calibration kit (fantastic kit, highly recommend). So I used it to back up factory tune and load the ford performance tune. Additionally, it can be used change the settings for gear ratios (up to 4.09) which I am looking to do as well.
Troubleshooting (DTC) , service and data logging. Scroll down to page four to see what it can do.
https://performanceparts.ford.com/download/instructionsheets/FORDINSTSHTM-12655-F.PDF
Seanuf99
St Louis Area
Sean
2021 Mustang GT
Bike computer and phone GPS are exact match to each other as far as speed goes. Speedometer is reading .5-1.0 MPH slower depending on speed. I am aiming for perfection, so going to play with the Revs/Mi setting a little more, see if I can get it any closer (but I doubt it). Just thought I would let you know the progress.
Epiphany
Global
I asked as I have an earlier ProCal and it performed similar functions. I had yet to see anyone report on the latest ProCal FP offers. Very nice.
m3incorp
Georgia/Colorado
James
Hey thanks for the update. It may be tough to get it read exactly the same as the gps.I commend you on aim for perfection.....can't say I would not do the same thing. :)
RobZ71LM7
Louisville, KY
Rob
2021 Mach 1, 2019 F-150
Wonder if it's a more warranty friendly option when just changing tire sizes versus an aftermarket tuner.
Charlemagne
Czech Republic (Europe)
Nick
Perfection is useless, have it perfect with new tyres and it will show something else with somewhat worn tyres.
