Tire size.
DoubleD76
Thomasville Alabama
Daryl
2021 Mach 1
I’m new here and just purchased a 21 Mach 1 without the handling pack. Has the Recaro seat option and 6spd. The previous owner put a set of SVE Drifter wheels on it that appear to be 19x11 all the way around. With 285 35 19 nitto 555g2 tires on them. I was wondering if I could put a bigger tire on the back to help the highway rpm cause it’s my daily and I drive 110 miles round trip to work and right now at 75mph on the dash actuall only running 71 and turning 2200rpm which seems a bit high for highway running. Thanks for any info that you could share.
MrMike
US
16 Mustang GT, 23 Bronco Wildtrak
285/35R19 is a bit of a stretch on an 11" wide wheel already. You really should have 305s.
You don't really have a lot of options for taller tires on an 11" wider wheel.
I would suggest getting 19x9.5 or 19x10 square or a Ford Performance Pack wheel set / Mach 1 wheel set to revert to stock. The 5-spokes go for $1k at a few places.
Idaho2018GTPremium
Idaho
2021 Camaro ZL1 A10
To match the factory tire diameter (275/40/19) with a 35 profile you’d need 315/35/19. I have no idea if that will fit in the fender well, but an 11” wide rim can handle it.
Tucker80
Aaron
2022 Mustang CS, 2024 Civic Type R, SV650
Much better options than the Ford Performance Mach 1 wheel set. They are ridiculously heavy compared to the SVE versions. I sold off mine and went SVE. Saved ~6lbs per wheel
DoubleD76
DoubleD76
Thomasville Alabama
Daryl
2021 Mach 1
Thanks for your reply
