5 spoke wheels max tire size rear
kendroz
PR
Kenneth
match 1
Can it be possible to run 295/35/19 or 305/30/19 on the rear 10 inch wheel?
Skye
≈39N
"Skye" Mach1 N2144
Skye
≈39N
"Skye" Mach1 N2144
From @Mikepol2
Very close to PP2 but not exact because of the rear tires being wider. All three are 10.5" front and 11" rear.
GT350 wheels are +30 front, +62 rear, 295/35-19 and 305/35-19.
PP2 wheels are +24 front, +48 rear, 305/30-19 square.
Mach HP wheels are +24 front, +52 rear, 305/30-19 and 315/30-19.
luc
CA
2017 GT with PP
Depend what your goal is, they physically will fit on a 10” rim but for max performance a 305 is better on a 11” rim
Since you don’t mention front tires, I assume that your goal is not maximum handling
Charlemagne
Czech Republic (Europe)
Nick
10" has recommended min 255 mm and max 285 mm. It will work with 295 mm tire fine. But I wouldn't go higher, it would look bulged and performance could be somewhat compromised.
Skye
≈39N
"Skye" Mach1 N2144
Attached is another tool.
https://www.1010tires.com/Tools/Tire-Size-Calculator
Factory 5-spoke:
19 in. x 9.5 in. (front) and 19 in. x 10 in. (rear)
255/40R19 (front) and 275/40R19 (rear)
The thread is young and we can let others chime in, but it looks like a 10" is going to be a bit skinny for what you want to accomplish.
The tire and rim combo could physically fit, but as @Sabre (and now others) have pointed out, they might not perform as expected.
I'm also concerned about the diameter of the tire. Using the calculator above, I'm not getting a warm fuzzy on the diameter. You generally want a replacement tire which is within +/- 3% of the existing; some can and do exceed 3% without ill effects.
Can you give us more details on the tires themselves and what you are trying to accomplish with them? That can help others provide additional insight.
Rapid Red
Woodstock GA
Greg
You're not changing the wheel, offset means noting. It's the width of the rim that is important.
Most tire sizes (all) will list the rim width min>max.
295/35/19 10" sure
305/30/19 10'' tea grabber answered that
Charlemagne
Nick
It looks somewhat bulged but I guess it is okay. Slight stretch is recommended for handling purposes. I would stick to 285's on 10".
