Radiator Fan Question
Leonidas514
Oviedo, FL
Chad
2015 GT
My car is torn apart, doing a turbo install. I need to wire my radiator fan and eliminate the condenser fan. With the car torn apart I cannot figure out which fan is which. Any ideas if the driver side or passenger side fan is the radiator fan? I want to use the factory plug but need to eliminate 2 wires from it and do not want to eliminate the wrong 2.
Soulja4187
Greenacres, FL
David
2021 Mustang GT Premium & 2025 Explorer ST
I have a 2021 GT what do you need to know. Pictures?
Dana Pants
Burlington MA
Dana
2018 GT PP1
It’s not a 1990 Miata. You just have two engine cooling fans controlled by the computer.
Leonidas514
Leonidas514
Oviedo, FL
Chad
2015 GT
hmmmm. Lol
So they both engage at the same time based on coolant temp? I'd think one would kick on with the AC or both kicked on at higher temps. So you're saying one isn't a primary fan? Thanks for clearing up the Miata confusion and for letting me know the computer controls the fan. It's guys like you that make this place awesome.
Soulja4187
Greenacres, FL
David
Was just curious which fans kicked on when the car got hot. Drivers, Passenger or both.
Well only one runs when it gets hot and the 2nd one runs only when the AC is on. Tomorrow I will check for you and post here
Leonidas514
Leonidas514
Oviedo, FL
Chad
2015 GT
Thank you! Don't want to cut the wrong wires. I'll only be using 1 fan.
Dana Pants
Burlington MA
Dana
2018 GT PP1
The two most important modes are both fans in series (~1/2 speed) and both fans in parallel (full speed). Removing one fan is a flawed idea.
Leonidas514
Leonidas514
Oviedo, FL
Chad
2015 GT
My car has no AC and only one fan due to the turbo location. I wasn't taking a poll, so if you've got no valuable input, move along.
Soulja4187
Greenacres, FL
David
Okay so when I just had the motor on only the fan on the right would run. It will be on your right when facing the engine bay. The left fan which is the lower fan only turned on when I turned on the AC. That fan is under the coolant tank.
Leonidas514
Leonidas514
Oviedo, FL
Chad
2015 GT
Thanks a million! Have a good night!
geddys
Europe, Poland
Mustang 2016 GT, Europe edition
Abit long reply, but I was doing same thing ( going from 2 -> 1 fan ). Here is electrical circuit. So its either one of them working, or 2 at the same time, but in 2-fan mode first fan gets ground in series through second fan. To fix that, first FAN should have permanent ground as its controlled with 12v side.
luca1290
Italy
Luca
That's not how the ECU actually actuates them.
The norm is that for low speed operation it's both of them at low speed (series), high speed is both them at high speed (parallel).
They are arranged this way for simplicity of operation, fault tolerance and lower noise.
geddys
Europe, Poland
You are right. I've looked again at the schematics, They achievie switching between series and parallel mode with FC2 relay, which makes fans run faster/slower
