Question for 15-17 Performance Pack Owners!
tdstuart
Arizona
Triston
2015 Mustang Gt Premium
I know the performance pack cars come with a physical oil pressure gauge, but are you able to see the actual oil pressure in the infotainment display on your gauge cluster or does it just show Low/Normal.
Trying to see if you install an oil pressure sensor on a non-performance pack if that is something you can add. Thank you!
Strokerswild
Shallow and Pedantic
Southern MN
Things With Wheels
Mines in storage so I can't look but I believe the physical gauge shows the pressure and the digital gauges in the dash only have oil temp.
Fairly certain this is correct. Mine is hibernating as well, so I can't easily check.
Crew4991
Phoenix Arizona / Denver Colorado
Crew
Ford Mustang GT/CS, Dodge Viper SRT10
Hey OP, the digital gauge cluster behind the steering wheel will only read oil temp. The gauge that came on the performance pack will read the pressure. It is likely that you could install an oil pressure gauge aftermarket on a standard GT model.
GT Performance Package includes unique front air splitter; strut-tower brace; larger radiator; upsized rear sway bar; heavy-duty front springs; unique chassis tuning; K-member brace; Brembo™ 6-piston front calipers; 19" x 9" front and 19" x 9.5" rear Ebony Black-painted aluminum wheels with 255/40R19 front and 275/40R19 rear summer-only tires2 ; unique electric power-assisted steering, ABS and electronic stability control tuning; Engine Turn aluminum dash panel; Gauge Pack (oil pressure and vacuum); spoiler delete; and 3.73:1 gear ratio with TORSEN® helical gear differential
Source: 2016 Ford Mustang e-brochure
https://cdn.dealereprocess.org/cdn/brochures/ford/2016-mustang.pdf
tdstuart
tdstuart
Arizona
Triston
Thank you guys for the responses this seems to be inline with my testing, very appreciated!
