17 GT with Ford Performance Pack 2
quabbinman
Homosassa,fl 34446
Ken
2017 Mustang GT PP,Power Pac 2
When using the no lift shit engine, breaks up Like the rev eliminator is cutting in ...is there a Ford fix for the problem
racrguy
Southern US
2019 Mustang GT
As far as I'm aware, there's no such thing as a '17 PP2, and Ford doesn't have no lift shift capabilities. The reason you feel like the rev limiter is kicking in is because it is. Bouncing off the rev limiter isn't good.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
Yeah.. no 17 PP2. Unless you wanna post up your window sticker showing otherwise.
poncho@home
GettingOld
Laval, QC
2017 Mustang GT Premium
I think he is referring to the Performance Pack 2 tune available from Ford Performance.
WildHorse
N/A or GO HOME
Puddintane
'17 S550
Haha.. and that's why I need hooked-on-phonics LOL
quabbinman
Homosassa,fl 34446
Ken
Thank you for your reply,You are right there is no PP2,I meant it to be Fords Performance Power Pack 2 which comes with the no lift shift option..
Fords exclusive no-lift shift strategy and enhanced throttle response will have you banging through all 6 gears without lifting your foot...That's right from the horse's mouth...but it does not work as it should,engine starts to break up at around 6000rpms...Mustang Forum has over 30 posts from Mustang owners with the same problem,but without any fixes to date...
I have been power shifting for over 50 yrs without it being an option...[although I did get towed home more than once]
i was hoping to find a fix on this forum...
Thank you again
Ken
Austinj427
CO
2017 GT350
Are we sure that's not how it's designed to limit RPM while flat foot shifting?
racrguy
Southern US
2019 Mustang GT
Aaah. Have you tried calling Ford Performance to see what's going on?
WildHorse
N/A or GO HOME
Puddintane
'17 S550
You might be running into the limiter, Try Shifting at 6 grand and see if does the same thing.
bloodocean
Mount Pleasant, SC
2017 Mustang GTPP
If you even lightly have your foot on the clutch anticipating a shift around full throttle, the no lift kicks in and cuts power, resulting in a stumble. Same thing if you feed in any throttle at all when letting the clutch back out.
In my opinion, it’s better to just get used to using no lift, karate kicking the clutch from a distance and keeping the gas pegged. It actually shifts pretty smoothly.
quabbinman
Homosassa,fl 34446
Ken
Are we sure that's not how it's designed to limit RPM while flat foot shifting?[/QUOTE
This info is from Ford Performance
  • Fits 2015-2017 Mustang GT
  • Features exclusive no-lift shift strategy and enhanced throttle response
  • Ford Performance calibrations feature exclusive Ford proprietary software and engineering
  • Ford Performance calibrations are 50 state legal with CARB EO (D-598-19)
  • Calibrations available for manual and automatic transmission
  • Allows gear ratio changes up to 4.09:1
  • Automatic calibrations feature optimized performance shift schedule
  • Premium fuel, 91 octane or higher, is required
  • NOTE: The Ford Performance Oil-Air Seperator - M-6766-A50 - does not fit properly due to throttle body stack up/alignment
  • Calibrations are for US and Canadian vehicles only
quabbinman
Homosassa,fl 34446
Ken
Are you saying that you should have your left foot hovering over the clutch pedal between shifts?...that would take some getting used to...I don't that was he programmers intent...
Thank you for your imput
ChitownStang
Chicago, North Shore
2021 Mach 1
Bloodocean is correct. I was one of the first with the pp1 and I had this same problem when shifting fast my foot was barely on the clutch pedal causing this engine sputter. Took a while to figure out what was happening. I disliked this no lift shift feature so much that I got rid of the pp1 for a steeda tune.
Nagare
Ft Lauderdale
2017 Lightning Blue V6
meh, you're fine. It's more of a consistent issue everyone seems to have with reading online. Ford Performance released a Power Pack 1 (M-9603-M8), 2 (M-9603-M8A), and 3 (M-9452-M8).
Same as everyone that calls the Performance Pack a Track Pack but I'll give them a little slack because that's a carry over from the S197s.
quabbinman
Homosassa,fl 34446
Ken
i considered using a Bama or steeda tune,but my car is a 17 with just 5000 miles, Ford will void the warranty if I do
I thank you for your input,
Maybe there is a Ford rep out there reading theses posts here and on other Mustang Forums
