DivineStrike
Doomsday
- Jan 30, 2014
- Charleston
- 15 GTPP, 11 F150 FX4, 07 CBR600RR
Good info mostly, except that a larger braking surface does allow for shorter stopping distances. Just because a 12.4 in braking surface can engage ABS doesn't mean it equals the same braking ability or stopping distance in a 15 in rotor. A 12.4 in rotor needs more hydraulic force to engage ABS. A 15 inch rotor requires less, which inherently also requires less time to build the pressure you need to engage ABS. Granted this amount of time isn't a lot but it can save you a couple feet, maybe more. I would have to do a comparison test to be sure.tbonez got the basics, I'll go into it further:
Large Brake Rotors: How these improve braking is counter-intuitive. The sole premise of brakes is to take kinetic energy and transmit it into heat energy and then dissipate it (ironically this is how your shocks/struts work too). Larger brake rotors increase brake torque which makes for a grabbier brake pedal (IE: more brake torque sooner) and it allows for more heat to enter the system before it overheats. More brake torque does NOT translate into shorter stopping distances because there is enough brake torque with smaller systems to cause ABS engagement. If you aren't familiar with what ABS does, the sensors detect when a wheel locks up and then it pulses the brakes to cause them to engage and disengage rapidly to bring the car to a controlled stop. In order for your wheels to lock up the amount of brake torque has to be high enough that the friction caused by the rolling tire on the roadway is overcome by the friction between the brake pads and the rotor. A 05-09 Mustang with 315 wide Hoosier A6 autocross slicks (arguably one of the stickiest tires in the world) will still hit ABS with stock pads, stock rotors and stock fluid without issues. What this tells us is that tiny 12.4" rotors on the 05-10 cars is MORE than plenty to handle locking up super wide and super sticky tires. IE: Adding brake torque will not stop the car quicker.
So that leaves us with slightly better initial bite with the brake pedal and a larger heat sink. A larger heat sink allows for more braking events before you either boil the brake fluid or fry the brake pads or warp the rotors. That's all that you gain from larger rotors.
The calipers, the 4 piston Brembo's for the EBPP and the 6 piston Brembo's for the GTPP offer better rigidity and a larger heat sink too. That rigidity translates to better pad wear and more consistent braking performance. Very important for track day guys looking to get the most out of the braking system in the car.
With that said I believe the Mustang has a booster which senses how fast your pressing the brake pedal so it automatically increases pressure faster, minimizing this benefit even more. Can't remember the systems name. Ah hah, found it really simple name lol. It's called emergency brake assist
[ame]
Do you get driving advice from the back of a cereal box!?
