Whiskey11
Kill ALL the Cones!
When what you are talking about first showed up on the S197 chassis in 2007 (due to the GT500 power level) it was called an A-Arm brace, not a K-brace.In the Mustang world, the brace you describe is called the Strut Tower Brace. A K-member brace triangulates the K-member, the cradle which holds the engine and mounts the Lower Control Arms. This brace keeps the LCAs from moving inward during high-load situations, stabilizing the front suspension and the front alignment.
I can only speak to the effect on a Fox. A Strut Tower Brace is a night-and-day difference on that floppy old structure. It's so dramatic it's always one of the first things I do when I get a new Fox. I've done the K-member brace a couple of times, and have skipped it more often. It's subtle, but you can (on the Fox) feel a little difference in front grip and stability. The more solid the structure, the less the body moves in reaction to impacts, and the more the suspension complies. Sure is easier to dial in a suspension if the body is not whipping around like al dente linguine.
I can't imagine the S550 will be even faintly related to the Fox, flexibility-wise, but the K-member brace can't hurt on track days.
All that said, if Ford has come up with a new name for a strut tower brace, I'll stand corrected. But those are the terms the industry has been using for 25 or more years.
I guess my assumption was they were articulating the reasons why some variations don't have a triangulated Strut Tower Brace and calling it a "K brace" since they don't call it a K-Member Brace. A conventional 2 point brace does a grand total of fuck all for increasing chassis rigidity on the S197 as it ties the strut towers together and forces them to move in the same direction. The only time it really "works" is during braking events. The S197 had a false firewall so a proper 3 point brace (the two towers together and then the firewall) would not have worked. I'm not sure why they wouldn't just call it an A-Arm brace like it actually is.
I see now that all of the recent S550 display models we've seen have the triangulated strut towers so you must be correct.
As for your Fox chassis, a lasagna noodle has more rigidity when boiled for 10 minutes than the Fox Coupe has from the factory. Anything you do to add stiffness is going to make a huge impact. The S197 chassis does not benefit nearly as much from the same bracing. The 2 point STB on the S197 doesn't do anything for rigidity as I said above. It doesn't on older Mustangs either. The benefit only comes when you tie the strut towers into something that doesn't move in the direction the strut towers move. The firewall is the most common.
Do you get driving advice from the back of a cereal box!?
