I Bleed Ford Blue
- Nov 24, 2018
- North East OHIO
- Mike
- 2023 grabber blue metallic Mach 1
Does anyone know the center to center distance of the mounting holes on the front calipers? Also is the front spindle the same on all S550 mustangs, excluding the GT 350?
The reason I ask is I stumbled across a guy on YouTube who is using 4 piston brembo calipers from a caddy ATS-V and mounting them on SN-95 spindles in a fox body and using 13" sn-95 cobra rotors. He has to modify the spindle and the ears on the calipers to make it work, so I suggested to him to look into the 4 piston GT brake calipers from our s 550's. With them being an actual ford part they might require less modification to make them work.
