QA1 GT350 CF Driveshaft
Epiphany
Epiphany
Global
I like to disassemble things.
QA1 has been great. They didn't blink an eye and asked me to send it back. They emailed me a return label in short order. While waiting for the label I pulled out the shaft for a closer look and took a few photos. Right click/view image for higher resolution.
On my low budget WalMart scale the shaft weighed showed as 20.2lbs.
For reference, I pulled out a factory 13/'14 GT500 CF shaft I have and weighed it as well.
While I'd like to discuss the differences/similarities I'm showing both CF shafts here simply so everyone can see how close they are in terms of length.
Ford uses a box that is not much longer than the shaft, double wall. The QA1 box was foam filled for about 1' on the end that nearly sheared off. I wrote QA1 with a couple of suggestions and they responded in kind and promptly at that. Interesting to see in a post up above about a similar shipment issue.
Enough about boxes and on to the details. Again, I paid the additional for the SFI label as much as the construction is the same whether you get a label or not.
The fact that the shaft was tested and SFI approved was a major factor in terms of my decision to purchase. My concern wasn't the billet aluminum ends, the u-joints, or the fiber tube itself but rather the bond at the joint where the yokes are adhered to the tube. Take a look at the test criteria starting on page 3 of the relevant SFI PDF. Note how both static torque testing and cyclic torque testing are done.
http://www.sfifoundation.com/wp-content/pdfs/specs/Spec_43.1_032409.pdf
I have seen photos in the past of DSS CF shafts where the bond failed and the yoke ends spun inside the tube. Ford used splined ends on the '13/'14 GT500 shaft, the only one I've seen done that way. So the bond at this critical juncture(s) is something I've paid close attention to. When QA1 talks about the 11 step process and the 3M adhesive they use they are in essence stating that they are well aware of the critical nature of the manufacturing process and are going all out to ensure that the bond is a success. The SFI test would expose a failed bond rather quickly. So this silly little sticker that most don't give much attention to means a hell of a lot.
Shaft balance...QA1 doesn't try to bond a weight to the fiber. Instead, they index different thickness horseshoe washers under the bolts for the CV joint. These are carefully placed during balancing and then marked so that the installer can replicate their placement when bolting the shaft to the car. Note the difference in thickness...
They also drill if and where necessary on the end itself to further fine tune.
The flange yoke comes from Sonnax, a well respected aftermarket driveline component aftermarket supplier located in Vermont. Scroll down to the bottom of the following link and you'll see the 1350 joint style used for this application.
http://www.sonnax.com/parts?categories[]=1&types[]=Flange+Yoke
QA1 is using a bondable yoke from Sonnax as well that is specifically designed for use with Cf shafts.
http://www.sonnax.com/parts/4424-bondable-yoke
The u-joints are from Dana/Spicer, another well respected company and Tier supplier to the OE's.
http://danaaftermarket.com/part/id/115604?cat1=115&str=5-1350x&cp=0
The CV joints are from GKN, yet another Tier supplier to the OEM's as well as the aftermarket.
Quite a bit of data from GKN in the following link regarding these joints.
http://www.gknservice.com/fileadmin...h/CV_Driveshafts_Industry_SpecialVehicles.pdf
I don't know who is doing the flange adapter for QA1 be it Sonnax, done locally or in-house at QA1 but it is a beautiful piece as well.
With heavy hitters such as Dana, GKN, Sonnax, 3M, providing support to an already well established company in QA1, my confidence level is very high in this piece. The service they are giving me is far more than I would have expected and I cannot wait to add this one to my car.
A few more photos for your viewing pleasure.:)
Greg35
Oklahoma
Greg
' 18 GT350
Great write-up Tob! :) Particularly pleased to see the info. your shared on SFI certification. As you know from photos of mine I sent you, I too opted for the SFI driveshaft. I just felt real good about quality measures taken during construction of this part. Your shared information has further reinforced that. Always good to have a high confidence in your shaft, right? :thumbsup: Look forward to your impressions after install.:)
stanglife
Jeff
1993 Coyote Coupe
Too pretty to install under the car.
Greg35
Oklahoma
Greg
' 18 GT350
:amen: Laid mine out in living room so I could "go over it" ea. evening prior to install!
H6G
IN OMNIA PARATVS
Far from home.....
'17 GT350
So... why would they choose an adhesive, instead of splined ends? Is there an advantage?
KiLLeR2001
Orlando, FL
'89 240SX, '17 GT350
Can't wait to hear your thoughts once you install this. I have been on the fence with upgrading the driveshaft since I bought my car.
Demonic
Boston
GT350R
This is the best advertisement for the shaft they could have gotten. Appreciate it.
Epiphany
Epiphany
Global
Jamal Hameedi, Global Performance Vehicle Chief Engineer at Ford, made a comment regarding the ends Ford designed for use on the '13/'14 CF GT500 driveshaft as being rather expensive. I don't know if Ford got a patent on it or not. I only know that they were case hardened and that Neapco pressed the ends into the supplied CF tubes. I believe they used CF tubing from Toray.
I saw in print that Ford was supposed to be pressing their ends in dry, without any adhesive. I've had a few of these shafts and each showed evidence of something being used, as much as it may be sealant.
Since Ford wasn't producing the CF tubing it was very important for them to ensure the supplied tubing was within tolerance. That's the nice thing about QA1 laying up/winding their own CF tubing - they have total control. While I have seen GT500 CF shafts that have snapped in half I have never seen evidence that a failure occurred at either end where the splined yokes are pressed in. If you web search (try "DSS driveshaft fail" for example) you'll see images where non-splined, bonded ends, spun within the CF tubing. I didn't post anything here because I believe DSS has worked through those failures just as every manufacturer does. As I mentioned earlier, for me, the proof in the pudding lies in the testing QA1 does on each unit prior to shipment. I don't plan on doing 100 or more drag-style launches on slicks but want to be sure I don't suffer a random bond failure that leaves me stranded in the middle of nowhere. Based on what I've seen, read, and been told, I'm at ease with the methodology QA1 is using.
KiLLeR2001
Orlando, FL
[MENTION=19066]Epiphany[/MENTION], do you know the weight of the stock GT350 driveshaft?
mustang_guy
United States
it has an engine!
Been looking at one of these units for My GT. I can't stand DSS. Glad to see they are as nice as I read.
I need to contact them and see if they make one that works with 6060 swaps.
JT1
PA
2021 GT500 CFTP, 65 FB
You are sending it back for inspection? Or have you found shipping damage?
Epiphany
Epiphany
Global
@Epiphany , do you know the weight of the stock GT350 driveshaft?
One of the guys I spoke with that purchased one of the QA1 CF GT350 shafts weighed everything. All the components used for the stock two-piece shaft came in at ~31lbs.
QA1 will custom make a shaft for you but needs to know certain pertinent information, obviously. The following link is to their custom shaft page. On the right side are two PDF links that contain most all the data they need, depending on your power requirements, etc.
http://www.qa1.net/driveshafts/how-to-order-a-custom-driveshaft
I couldn't visually see any damage and I made that clear to QA1. I'm not the type to complain but felt at the very least that they should know how their packaging was holding up. Driveshafts can get damaged rather easily (in terms of balance) when dropped. To wit:
Look closely at the sticker on my original steel, two-piece GT500 driveshaft on the left. "Scrap If Dropped" isn't exclusive to Ford shafts either...
'13/'14 GT500 CF shaft...
This label from a Nissan 350Z CF shaft...
Simply put, any driveshaft should be handled with care. Some have internal balance "mechanisms" which can be easily damaged if mishandled. I'm sure QA1 will thoroughly inspect the driveshaft visually and possibly check the balance. Beyond that, I honestly don't know what they will do. The fact that they didn't hesitate to have it sent back speaks volumes to me.
