Project Stocktonaut
Status
Not open for further replies.
highvoltage
NorCal to SoCal
Brock
24 Mustang GT Atlas Blue, 23 Race Red Bronco
I was really looking at getting the Mishimoto intake tube. Seems it works well with a better filter. Glad I found this thread again. Forgot to sub to it. If you switch intakes and wanna sell that intake tube let me know. Thanks for doing all this great testing on yours and others products.
stoli
Fat Guy Racing
Lakeland, FL
'15 Black GT/PP
Also forgot to add. My custom valved Viking Double Adjustable Front Coilovers are in.
I am going to use the following combo.
Viking DA Front Struts (AK valving)
300lb/in Coilover Springs
BMR Custom End Links (pictured)
Stock Front Sway Bar (PP)Rear BMR SP085 980lb/in SpringsViking B358AM Rear Shocks
Stock Rear Sway Bar
BMR ELK014 Rear Bar End Links
Once I get this set up tested - I will move onto sway bars based on what I feel the car needs.
We have a SUPER BADASS new front sway bar coming....and also a revised front sway bar mounting system - so I will likely be showing those off soon. I am thinking thr 35mm front and 25mm rear will be the ticket. But we shall see.
If you need another test mule I may know someone local that hits the track pretty regularly with some well established baseline numbers to work from. :)
BMR Tech
BMR Tech
Tampa, FL
www.bmrsuspension.com
Dion
Well things are about to get interesting.
amg1
usa
2015 Mustang GT
grrrrr
stoli
Fat Guy Racing
Lakeland, FL
'15 Black GT/PP
They look great, but how are you supposed to adjust them at the track? Those knobs are down behind the (extremely hot) rotor in about the absolute hardest spot to get to on the suspension.
TwinReverb
OKC
Alan
2016 Mustang GT PP
I'm interested to hear more about this new sway bar. Based on the track day last Sunday I think some sway bars are in my near future.
https://flic.kr/p/Vw5P8R
BMR Tech
BMR Tech
Tampa, FL
Dion
That's odd. I was thinking it was actually the easiest spot.
Walking up to the car, I could get both shocks adjusted within 30 seconds after you say "go". Probably 15 seconds if you didn't make me go up to the 10+ settings. :cheers:
As for the heat. I don't think I would try to adjust them when the car is hot off the track.
:headbang:
BMR Tech
BMR Tech
Tampa, FL
Dion
So I have had the coilovers on the car for a while now.....and figured it was time to go ahead and get the BMR SP085 980lb/in springs on it and also replace some test prototype stuff out with the production pieces.
I am replacing the test prototype TCA048 Poly Bushing Vertical Links with the TCA047 Delrin versions, and I am replacing the UTCA057 Poly/Bearing Camber Links with the UTCA064 Delrin/Bearing units.
I am also installing the just released BK081 RLCA Bearing Kit.
BMR Tech
BMR Tech
Tampa, FL
Dion
Not many updates to share. I have the suspension REALLY close to where I want it at this point.
The last piece of the puzzle for me is our Toe Links. I have been slow and methodical on my suspension approach, but finally I can move onto other areas soon!
Status
