SolarFlare
Dont recall and im not by my car right now. If you have multiple tunes in the nguage, does the nguage tell you which one is currently uploaded?
Well fantastic lmao, and you're a manual. Ill try it out now on the way home so see how and when it does it and ill try to log it. Ill try to get under the car and check that line from the inlet to the BOV to see if I see anything.My car has also developed this surge issue. It will do it around 2500rpm or so, usually in 3rd and up if I give it a certain throttle percentage. You can see on the RPM graph from the log that its wavy with peaks and valleys when it's happening. It didn't have this until I added a return system and switched tuners. Tuner says he doesn't see anything in the log, and to check the bypass valve. Well I haven't touched the Tial BOV except to tee off the vac line for the regulator. I don't think there's any kind of leak, because it holds boost all the way up on WOT pulls according to my gauge. I'm kinda stumped right now.
Makes no power.So educate me here. I’m considering the P-1X down the road and already decided against Lund for reasons unrelated to this thread. Question is: what’s wrong with the tune from procharger. Is it because it’s more conservative and /or most people already have a Lund? And what is ProCharger’s stand on this issue?
No I don’t think so...I was looking around on the Ngauge trying to figure out if it said somewhere which file was currently loaded, but I couldn’t find anything definitive.Dont recall and im not by my car right now. If you have multiple tunes in the nguage, does the nguage tell you which one is currently uploaded?
Mine gave engine trouble codes and caused the catalytic converters to get up close to 2000 degrees. They fixed that with a revision and then a month or two of back and forth revisions (I think there were 9 revisions), none of which could fix the surging issue.So educate me here. I’m considering the P-1X down the road and already decided against Lund for reasons unrelated to this thread. Question is: what’s wrong with the tune from procharger. Is it because it’s more conservative and /or most people already have a Lund? And what is ProCharger’s stand on this issue?
I don’t have imrcs. Boss intake. Nothing has changed about my setup except switching tuners and going to the return system w/regulator.Is it possible the IMRC's have started playing up?
My car lund tuned always drove great, no surging.Has procharger chimed in at all? I was about to pull the trigger on HO kit now I'm worried...
I really believe it's in the torque management tuning,I had the same problem with my pp car and could never get it to stop,one thing I would look at is make sure the linkage for the surge valve is not hitting anything and I would use a vacuum reference that just runs the surge/ blow off valve.I don’t have imrcs. Boss intake. Nothing has changed about my setup except switching tuners and going to the return system w/regulator.
