Procharger belt question
horsepower addiction
Arizona
Nate
s550
Take some rope and run it around the pulleys like the belt. Have someone hold the tensioner then mark the rope. Take the rope out lay it straight and measure it
Medusa5oh
Medusa5oh
www.instagram.com
Cullen
2017 Mustang GT PP1
That really makes me think this belt is too short then if you have smaller pulleys and your belt is longer than the one supplied. Sounds like it’s not even a little too short it’s way too short for oem components just going off that comparison. I’ll try to the rope trick just out of curiosity
wingnutt
@FL410
michael
350R Procharged w/P1X
For what it’s worth…ProCharger sent me a belt too big, and I was having a devil of a time keeping it on the pullies.
wait until you can call them 😬👍🏼
BullittBoy
Annapolis
2020 Bullitt-2024 F150-2023 MACH 1
I would do this and see if it matches what Procharger tells you. Make sure you pull the string tight and you use the same "rib channel" on all drive pulleys to get the absolute correct measurement.
wingnutt
@FL410
michael
Medusa5oh
Medusa5oh
www.instagram.com
Cullen
2017 Mustang GT PP1
sorry yall I’ve been at work all day and was waiting for my buddy to be available. Sunday was busy so we called it a day in the early afternoon.
I Called procharger and after talking to a customer service rep, tech, and finally an engineer they told me the belt supplied was right for the 3.60 pulley and stock everything else.
However they also gave me the part number for one size up which is typically for the 3.80 pulley but said some customers have had better luck with that on the 3.60 (little confused on why they’d recommend two belts for the EXACT same pulleys/balancer setup but all good!).
he’s picking up that belt on his way (gates 060888) home to try and we also will measure as yall recommended just to compare results if that belt doesn’t fit.
give me a few hours and I’ll have an update this evening!
wingnutt
@FL410
michael
Understood, and that’s SUPPOSED to be the beauty of their additional tensioner…because it has more range, to allow more pulley sizes without belt swapping 😉
Medusa5oh
Medusa5oh
www.instagram.com
Cullen
2017 Mustang GT PP1
Unfortunately that’s the problem with this setup, no additional tensioner relys solely on the Oem tensioner. I’m actually surprised how “simple” this setup is compared to other kits without multiple idlers and/or tensioners added.
Medusa5oh
Medusa5oh
www.instagram.com
Cullen
2017 Mustang GT PP1
Well I think (fingers crossed) he is in business. He picked up the one size bigger belt per procharger and left it hanging in the sun the last hour to maybe help get some extra stretch from 100 degree heat. It was tight to get on but it was doable, and then the factory tensioner put quite a bit of tension on it. Seems like we are good, just waiting on his tune to fire it up hopefully tomorrow, and then we will know for sure! I’ll keep everyone updated!
Medusa5oh
Medusa5oh
www.instagram.com
Cullen
2017 Mustang GT PP1
Still waiting to update yall, car has been done just waiting for a tune to start it still. Hopefully today!
Medusa5oh
Medusa5oh
www.instagram.com
Cullen
2017 Mustang GT PP1
Everything seems good so far, currently doing some data logging back and forth but it’s the weekend so we won’t know much until Monday! Have a great weekend everyone!
Arizona
Nate
s550
After you get it going you should data log or at least watch for knock. My procharger tune had a lot of knock. Just keep a eye on it for awhile
Medusa5oh
Medusa5oh
www.instagram.com
Cullen
2017 Mustang GT PP1
Was your tune the one from procharger or was it Lund? His is Lund tuned
Arizona
Nate
s550
Procharger. I just figured since he has a 50 state legal kit he would be running the legal tune. Guess I should have asked
Medusa5oh
Medusa5oh
www.instagram.com
Cullen
2017 Mustang GT PP1
Lund wrapped up his car today. Sorry for the delay it was hard to get data logs done and sent back between his work schedule and Lund leaving for the day, however the car drives amazing and only took 2-3 revisions to dial in from start to finish. He’s super happy with the final product but from how it sounds, and one size up in belt was the way to go.
He does keep considering finding a way to get the belt it came with on (using the same methods he used to get this belt on) but I told him unless he starts getting slip or any belt related issues I’d continue to run it! This belt isn’t loose and has proper tension so to me it sounds like the way to go (as well as Lund and procharger)
