PP Brakes for Track & Daily
chunter415
Seattle area, WA
2018 Mustang GT PP1, 2019 F150
Recently I was able to go to an all day track event near me learning how to drive on a track and then spending the afternoon with teachers helping me learn and damn was it fun! I was defiantly nervous with my brakes as I've heard that from other posts the stock PP Brembo brakes show fade at temp, and while I don't believe I noticed much I did notice a decent difference in pedal feel from before and after the track day. I'm wanting to do it again, but looking for some advice from those that have done track days. Do you believe I'd be okay getting another track day (15-20 min lapping sessions) with 3-4 intervals and about 20 min cool down between each session still utilizing the stock PP brakes? Or should I spend the money and upgrade to track focused pads, and if so will the rotors be okay with me switching out the pads for track day, then back for daily?
The track has a good amount of braking on it, Pacific Raceways in Kent Washington. At this point track days will probably only be 2-3 times per year, so while down the road I might upgrade rotors and pads I don't know I'm ready to go that far now though again looking for advice on what others have seen work well.
Thanks everyone, this is something I've been looking forward to doing with my Mustang and it handled wonderful, I know this will only be the start on upgrades!
2018 Mustang GT, PP1, 10 speed
luc
CA
2017 GT with PP
You simply have the wrong pads for the track
The factory pads are not designed for medium to serious track work
With the correct pads, the pp braking system is fantastic
chunter415
chunter415
Seattle area, WA
That was my suspicion, do you have any suggestions for pads? Should I keep the rotors or replace them as well?
WCRookie99
Illinois
G
2021 Mach 1, 2007 FR500C, 2022 LH5
Absolutely, the wrong pads. I would search this forum to find out what people use. Plus change your Brake fluid to Castrol SRF.
So, here's my take. Mustangs today are fast and even going 7/10th around a track, speeds are high. Most beginners braking technique are actually more dangerous as they brake like normal driving, which overheat the pads rotor and fluid by 2x.
Normal driving, when you approach a stop sign or sharp curve you put your foot on the brake, then as you get closer you press harder and harder and if speeds are high by the time you're close to the corner you're standing on the brake pedal. On a Race track if you do this for one or two laps, you will boil the stock fluid and cook the pads.
Proper technique for Braking on a Race track is actually the opposite of street driving. When approaching a turn (at speed) you press the brake pedal super firm first, then as you get closer to the corner you remove pressure from your foot.
Two thing happen, you're on the brakes for less time and as you turn into the corner the rotational inertia and friction of your tires slows the car down. Now this is something you need to built up to because if you try just slamming on the brakes and letting off and turning the car in the corner, chances are you'll spin out if you didn't scrub off enough speed.
So, caution, level head and situational awareness and slowly build up speed each session is recommended.
I would also get to know when and if the ABS kicks and how that effects your stopping.
Lastly, if you're just playing around on the track at 5/10th -7/10th max, I'm ok with a street car. However, if you (you I mean anyone) start getting faster, you're getting into the zone that I would buy a Track prepared Race Car with roll-cage. Why?
I've seen too many parts fail, that wined up a bad day. Brake fading, fluid boiling are the worst. Rear halfshafts or suspension breaking are next, front/rear hubs and bearings and even wheels cracking/breaking. How do you know how long these parts will last?
Race Teams catalog each part, x-ray for cracks and replace parts way before they fail. Also do a lot of testing. I know Track days aren't Racing but speeds are high with today's cars that stress on stock parts are super high.
Enjoy, have fun but keep it safe.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
If thr brake feel has changed, you probably need to bleed the calipers to get dirty fluid and / or air bubbles out of there. Its possible you may have glazed some pad material but the knly way to check that is to pop a couple pads off and inspect the friction surface. If you haven’t touched the fluid yet then 100% flush it witha good track ready fluid like Motul 660 or SRF.
the PP pads are actually pretty good for beginners on track, but checking the pad surface for glazing would tell us more about the true condition after your track day.
AMC401V8
Kentucky
2020 Mustang GT - 2000 Excursion - 1987 Swift DB2
How does changing the brake lines to braided have an effect on fluid temperature? This is something I would like to understand. Thanks in advance for your reply.
Ewheels
SoCal
Eric
'18 GT PP1, '23 F150, '24 4Runner Pro
Braided lines do not do anything for keeping temps down. The heat is transferred from the friction between the pads and rotors through the caliper pistons and into your brake fluid. The material the lines are made of make no difference to temperatures.
The reason for braided lines are improved pedal feel, keeping the lines from expanding (which you mentioned correctly) and durability so the lines don't tear from heat and debris hitting them. Has nothing to do with cooling...
  • Like
Reactions: luc
