Please help!! Installing crank sprocket.
boostedpp2
georiga
doug
2019 mustang gt pp2
What’s up guys. I am installing a crank sprocket on my 2019 pp2. The stock sprocket had to be taken off with a puller, and the aftermarket sprocket will not just slide on. Am I good to just tap it on? Thanks
OldbutNew
S.E.Michigan
Greg
2019 Kona Blue GT 10R (Wife's car) 2018 Mustang GT Royal Crimson PP1 Manual
Something is up. You should NOT need a puller to get the production sprocket off. OR a hammer install one.
How closely have you inspected the snout and key?? The crank damper? Did this engine see a supercharger at some point?
Wait... Boosted PP2. (sigh)
boostedpp2
georiga
doug
2019 mustang gt pp2
No it only has 24000 miles. The crank looks perfect.
Zrussian13
Phoenix
The sprocket should slide right on. The harmonic balancer can be tight. I used a heat gun to get it off and on but the sprocket shouldn't have an issue.
EFI
Masshole central
5.Br0
The sprocket should slide on and off like butter. If it's fighting you either something is galled or the snout or new sprocket is out of round.
deanm11
Northern NJ
Dean
2020 Mustang GT A10
Agreed, both stock and aftermarket should slide right on/off with almost no resistance.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
I've done a bunch of these. A little bit of friction on and off is not uncommon.
OldbutNew
S.E.Michigan
Greg
A "little bit" is one thing. Having to use a puller to get it off and considering a hammer to install is way beyond that.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Sometimes it takes a puller to get them off. The keyway fit is pretty tight. Once its off, he can clean up the snout, inspect and tap on the new on. It's not a big deal.
