Performance Package Brakes
fionic
spaghettios and cheerios
IL
15 GT PP
According to the Dealer Source Book, rears are single-piston on all trims. But they are at least good sized 13-inch rotors (GT & EB+PP).
shit, you're right. I'm remembering the wording differently. :)
"GT Performance Package features BremboTM 6-piston front and single-piston rear brake calipers
- 15.0" diameter vented front discs
- 13.0" diameter vented rear discs"
OppoLock
RWD Addict
St. Petersburg, FL
Sean
'15 GT, '20 GT350
Single piston calipers and and 13" vented rotors out back are hardly something to dismiss as mediocre. That should be more than enough to handle the heat generated in most situations save for strenuous repeated hot laps at a high speed circuit.
Increased piston count simply creates a more even braking force. Again, that's not going to be a big issue for the GT PP unless you're doing some serious track work. If needed, you could always opt for an aftermarket BBK setup and a brake bias adjuster/valve if you think you need added work from the rear.
Swoope
Zoom-Freakin'-Zoom
Orlando
Scott
15 GTI PP / 04 Rx8 track car
People need to remember that a fancy caliper with more pistons in the rear doesn't equate to better braking. One important thing people forget is the tires. The brakes will stop you as fast as the tires let you. If you don't like the single floating caliper in the rear, wait for aftermarket, get better tires or buy a GT350...
most correct statement in this thread. and if the tires start overwhelming the brakes, the pads are then next thing to change not the calipers..
beers
Papaya
Stony Plain, Alberta
Holger
F150 2.7 EcoBoost
6 on front, 4 on rear... what's the problem?
Ohhh sorry! I meant: (BREMBO on the front axle?) Put BREMBO on both axle please.
908ssp
Michigan
Alex
2015 GT/PP white
That is going to be much easier on the 2015. With the independent rear suspension the wheels don't move with the axle in and out, they ride in the same place relative to the upright, just like the front wheels. Adding fixed calipers is easy if still expensive. I would not be surprised to see them on the GT350. I'll probvably add them to my car as I did on my S197.
dpphoto
dpphoto
Albuquerque, NM
www.danpearsonphoto.com
2015 GT PP
2015 Brembo
Greetings, I am trying to order autocross wheels and need to know if anyone can give me the specs or the part numbers for the 2015 Brembo brake package on the PP? Thanks, dan :confused:
DivineStrike
Doomsday
Charleston
15 GTPP, 11 F150 FX4, 07 CBR600RR
Look in the wheels section, I created a thread about wheels fitting over the PP brakes.
As for the rear brake debate. I think the size is sufficient but I would like a dual piston setup for more even brake wear.
Grimace427
NoVA
2011 Mustang 5.0
Search for wheels that fit the '13-14 GT500.
