GT Pony
- Mar 13, 2015
- Pacific NW
- 2015 GT Premium, Black w/Saddle, 19s, NAV
The separate computer controlled "pressure control" valve used on the 2018+ 3rd Gen Coyote is for "fuel economy" purposes ... ie, it reduces oil pressure and flow at low RPM, and hence makes the pump work a little less which saves a few drops of fuel. It's basically like a secondary relief/bypass valve that must divert some oil flow back to the sump, which will decrease oil flow and hence oil pressure to the engine.Could the oil pressure be too high on cold starts without that valve?
Even though the valve was put there just for fuel economy and nothing else, that doesn't mean that the engine hasn't been adapted to work efficiently with it (i.e. to work best with lower oil pressures) - in which case increasing the pressure might be detrimental. Hot idle would certainly be fine, but what about 3000 rpm with a cold engine at 20 °F?
The oil pump still has it's own internal pressure relief valve like it has always had. So on cold starts and high RPM, the pressure is regulated to a maximum. The mechanical valve in the oil pump would still work as designed even if the separate computer controlled "pressure control" fuel saving valve wasn't working.
