Per Ford (officially) the 2011-2019 F150/Mustang 5.0 “Typewriter Tick” is a normal characteristic
Just putting this out here, as it’s the most recent communication (basically no change in Ford’s position on the subject matter):
GT 550
Australia
Black GT MT S550
Would be great if they said what it was. Their declaration that it's not detrimental suggests they must know otherwise they couldn't make such a statement.
GT Pony
Pacific NW
True, how hard would it be to say in the SSM what the cause was. My theory is it's caused by some big rod end side clearances being slightly out of spec on some engines. If it was something like that and they said so, it would look bad and some people would probably be upset to hear something like that. Big rod ends randomly dancing side to side on the crank journal at low RPM isn't going to hurt anything, just make some ticking noises.
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
My tick went away completely after I switched to Valvoline Extended Protection 5W30. But it was never a big deal anyway, I could only hear it occasionally if I really tried and was next to a wall or something. 5W20 to 5W30 isn't a huge increase in viscosity but it may mask a clearance issue like what you're describing, so there could be some merit to the theory.
GT Pony
Pacific NW
I think it's more related to the friction level of the oil, but the viscosity can also play a role in terms of "cushioning" moving parts. That's why adding as little as 150 mL of Ceratec (a friction modifier) makes the ticking go away almost instantly due to the change in the friction level between moving parts. The way the rod big ends behave on the crank journals may be effected at lower RPM by the friction level of the oil. Some motor oils have better friction reducing additives (like Moly) than others, so using a motor oil with a relatively high Moly content may help reduce the ticking. My theory is that the way the rod big end moves around on the crank journal is effected by the friction level of the oil. And if the rod side clearance is on the max end of the clearance range, or slighlty out of spec, that magnifies the ticking.
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
Valvoline EP has one of the highest moly counts out there so it definitely makes sense.
geep81
Cleveland OH
Glenn
2020 GT Premium
I've been using Ceratec for over 4 years now in my 2020, it has worked great and stopped the tick completely and I have had 0 issues with the engine. Have about 35k miles on the car.
After reading countless articles, videos, forum posts, etc, I think everyone who's really bothered by the tick just needs to add some Ceratec at every oil change and their problems would go away.
MrMike
US
16 Mustang GT, 23 Bronco Wildtrak
Mine has never done this. It's life has all been on Motorcraft oil until recently I put PUP in it.
Is the tick more common on Gen 1 and 3 than Gen 2 or does mine just not have it?
Jstang23
Jack
2023 Mustang GT Eruption Green
Same! Ceratec is the way to go! Not only fixes the tick but I've gotten 1-2 better MPGs and I've seen lower CHTs while on the track. Good stuff :like:
GT Pony
Pacific NW
Some Coyotes, regardless of the generation (the latest SSM 52334 shown above covers years 2011-2024), don't exhibit the ticking. So that also aligns with the ticking being caused by a parts tolerance stack-up.
Firsttexan
2011 GT500 '19 GT PP1 '13 GT500, 98 GT, 92 LX 5.0
My 2019 GT 19k miles did not exhibit the ticking noise described. Neither does my 2019 F150 5.0 with 32k on it.
I will say the Coyote motor is a noisy engine. You can hear the phasers rolling around and various other mechanical ticks and sounds. I did add Ceratec and it did quiet both down noticeably. In the truck I didn't notice any change at first, until I took it out for a 200 mile hwy trip. Of course this is all seat of the pants and not scientific. My ears say, it did make a difference. No gas mileage change etc..
TruckandaMustang
Calgary
Joe
2013 F150 FX 4 2021 Mustang GT
(Note to Mods: Posting this here initially as this is the most viewed sub-forum - please leave here for at least 24hrs before moving to the Issues/TSB sub-forum - thank you).
Yep, you’re all reading the thread title correctly...
Also notice how the document expands the applicable vehicle starting year as far back to 2011, covering prior F150/Mustang 5.0 model year Customer complaints/concerns.
Since this is an official release, I would not expect Customer concerns to get much traction, as this doc will be referenced to the Customer as being “a normal characteristic”... UNLESS the noise the customer is hearing is beyond a “typewriter noise, a tap or tick”.
Can anyone let me know if I can add the ceratec to my 2021 GT after I just did an oil change? Meaning that I have the full 9.5 litres of oil in there now is adding the 300 ml of Ceratec too much or will it be okay?
shogun32
Northern VA
95CobraR
Sandy Springs, GA
Doc
2019 Shelby GT350, 2023 Porsche 911 Turbo
.Can anyone let me know if I can add the ceratec to my 2021 GT after I just did an oil change? Meaning that I have the full 9.5 litres of oil in there now is adding the 300 ml of Ceratec too much or will it be okay?
I would have opened the oil filter after changing the oil. If the filter is clean, there is no problem.
If the oil filter has metal particles in it, you have a problem.
