Paxton Belt Slip
Tugger50H
STL
Tony
2015 GT
Just put on a gates RPM 100" belt on my paxton with 3.48 pulley. At first I had it on the 4th from the left hole and had slip and belt dust. Went to the third from left hole and the belt was fairly difficult to get on but no slip and no dust so far.
Tugger50H
STL
Tony
2015 GT
Also have heard good things about the American Racing Solutions HD tensioner. Probably my next upgrade even if I go with an 8 rib
Ponderthis
Ponderthis
Boost Loading...
Senoia, GA.
Chase
2015 GT Premium
Yea torn b/w 100, 100.5 or 101 lol...
TooSoonJunior
Southern CT
2015 Mustang GT PP M6
FYI most spring tensioners have a pretty linear spring rate no matter where in the travel you set them up. To ensure you don't hit the stops on either side of the tensioner using a belt that sets the tensioner somewhere close to the middle of its travel is best (or balanced out with the location of the manual tensioner).
Point is putting on a shorter belt doesn't necessarily mean you will have a "tighter" belt but just be giving the tensioner less travel. Sometimes that's a good thing, since too much travel can result in thrown belts or slipping.
The American Racing tensioners (Pricey) have much longer reach of travel and tend to have higher spring rates than factory tensioners. This gives more freedom to use differing belt lengths without much effect to slipping or throwing belts. I ran one on an older setup I had and found great results.
Even though you say you took into account the fact that the lines wont line up, I don't see how you could have done that unless you counted engine rotations during the drive cycle you tested, which is totally impossible. How have you confirmed you in fact have slipping? dust is not enough, every setup slips a little and leaves a dust residue.
Ponderthis
Ponderthis
Boost Loading...
Senoia, GA.
Chase
2015 GT Premium
I'm on the 101" HD gates now one hole to the right from center and pretty sure she's good now.
higdominator
Central Oklahoma
2016 GT PPP
Good to know in case certain belts aren't available. Now the question is which belt with a 3.33........:lol:
Pincushin3819
SC
17 Paxton GT
I'm going from the 3.48 pulley down to a 3.00. I have a 101 belt I think, would this still be best & which hole is preferable for the head unit? I have a 8 rib, 20% OD & just purchased AR tensioners for insurance with the 3.00. Terry [MENTION=10926]beefcake[/MENTION] & and anyone else that would know? Thanks!
beefcake
Bethel
2018 Ford Mustang
RubyRedBoost
Traded EB old name New GT
Fort Worth
Josh
2015 Guard GT with PP
What kind of boost are you seeing on the 3.48?
Ponderthis
Ponderthis
Boost Loading...
Senoia, GA.
Chase
2015 GT Premium
Im not 100% sure on what its actually making since I dont have a mechanical gauge, in theory if no slip they should make 14-15psi open blower at 7500.
RubyRedBoost
Fort Worth
Josh
I’m guessing there’s a chart or efficiency map explaining this? Sorry total newbie here.
Slamdcoop0428
SW Florida
2016 Mustang GT Premium auto
3.0 is going to overspin the 2200sl like crazy if you sre revving to a normal 7500rpn or so.
higdominator
Central Oklahoma
2016 GT PPP
I tossed a cheap gauge on the car while waiting for a permanent setup and saw 15psi @ 7500 with just a K&N on the blower inlet.
