One map light intermittently works
mookieit
tampa
john
mustang 2015 v6
My right map light socket is intermittently working. I tried another bulb and the same.
it works if I twist it a bit, but then when I drive the bumps move the contacts and then again the bulb wont work.
I am guessing the map bulb socket contacts are not contacting the bulb contacts.
Can you please suggest what I could do to fix this?
Adam the Lighting Guy
West Palm Beach, FL
Adam
2021 GT Convertable , California Special & 2020 Ecoboost Premium Coupe
Reach into the socket with a pick and give the contacts a bend. Be sure to either pull a fuse or disconnect the battery though.
FUN2RIDEFAST
Ofallon, Missouri
2017 Mustang GT Premium/PP
You might have a bit of corrosion on the socket. That'll definitely cause it.
