Oil change question
Jubilex
Norman, OK
2016 Mustang GT350
One thing I did notice . . . after the oil change I was getting a much greater range in oil pressure readings.
Before the change: idle would be at 75 psi, higher revs would be at 90-100 psi.
After the oil change: idle is at 60-65 psi, higher revs are now at 110 psi.
The higher oil pressure is also something I saw since performing my oil change. Even a little higher than your seeing. I used Amsoil 5w50.
montreal ponies
Montreal, Canada
‘17 Ruby red GT350
That's what i'll be using too. But i'm still missing the car . :frusty:
hal_farthead
Houston, Texas
2016 Shadow Black GT350 - Tech pkg
I'm going to throw this question out there, though there may be a more appropriate thread...
I'm a noob to big v8s, with my prior experience bring with i4s mostly. I have heard tell from some mechanics that anytime a motor is used for extreme duty, straight weight oils are preferred to multi-vis. First, would you more experienced guys agree that 30w or 40w oil is preferable, and if so, can you obtain it in a synthetic?
Thanks,
Spacebird
Boulder County, Colorado
2016 GT350R
Use exactly what Ford says: an oil that meets Ford's WSS-M2C931-C spec. That's either Motorcraft or Amsoil 5W-50.
If you don't your engine is guaranteed to explode the second you turn the key. Ok, probably not, but Ford engineers actually know what they're doing.
steveespo
New York
2018 Mustang GT PPL2, 2017 F-150 XLT SCREW
Anyone know of a filter cap socket that works for this filter?
Thanks
Tank
9/11 - Never Forget
Above the Notches
G0853
stang302
2016 GT350
Probably been answered before but I couldn't find it....
Amsoil website says their 5w/50 is Ford WSS-M2C931-C not B.
Thanks
Digging a bit deeper, Amsoil webpage clearly shows compliant with B.
http://www.amsoil.com/mygarage/vehiclelookuppage.aspx?url2=2016+FORD+MUSTANG+V
So I had called Ford and asked if this was an issue. Rep consulted higher ups and said as long as 5-50 full synthetic was used, it would not be an issue. I have a case number as documentation if it ever came to it. But honestly think it is a non-issue. I am using Amsoil 5-50 synthetic. But according to the Ford rep I spoke to, and the higher-up they consulted, warranty-wise, any 5-50 full synthetic is acceptable.
R1Jester
Chicago
www.r1jester.com
Tom
2016 GT350
I've got everything to change my oil this weekend. Not sure I've seen a full run down on "how-to". Anyone interested if I create a post with pictures? Anything specifically that people would like to see? I know I've seen some cut up filters posted but never really a how to on the change.
Kurac
NE Ohio
2017 GT350 R
Sure, I have yet to do my first at just under 700 miles. Should be straight forward but it never hurts to have as much info as possible before tackling a job. Thanks!
GT_Dave
NE Illinois
1970 Mach 1 408EFI , 2016 GT350
Make sure that you puncture a hole in the bottom of the oil filter and drain it before you try to take it off, otherwise your in for a messy change out.
RoadRacer
Skippack, PA
2016 GT350
Tru 'dat......I made a mess even using the plastic bag method. Good thing I had the whole area layered in shop rags. I'll definitely drain the filter on the next oil change.
Epiphany
Global
I like to disassemble things.
Just did mine. That is an excellent suggestion.
raiderjatt02
Bay Area, CA
Jessie
2016 GT350 - Track Pack; 1995 GT - Saleen Clone
I did mine yesterday and yuuuuuup. Plastic bag would have been useful. I took the filter off when the oil was barely dripping out of the drain plug. As soon as I got the filter off (which was on tight as hell) my whole hand still got covered in oil. It dripped almost down to my elbow. I'll definitely have a plastic bag handy next time.
GT_Dave
NE Illinois
There are a lot of rotations necessary to remove the oil filter a plastic bag is awkward. I used a gallon ziplock and still made a big mess. Maybe a 2 gallon size would have worked better.
