Official Ford Sync3 3.4 Release
tnk_2
New Mexico
Henry
2020 mustang GT, 401A, auto, CS, Ford SS.
I just checked the ford website sync update and there is a new sync 3.4.23188 now. However, when I check my car it's still 3.4.22251. I will wait and see if the car will update using wifi.
Soulja4187
Greenacres, FL
David
2021 Mustang GT Premium & 2025 Explorer ST
it will update if your car is within range of Wi-Fi otherwise it will never update. I did it and notice nothing new
Bikeman315
Myrtle Beach, SC
Ira
WiFi updates have always been a crapshoot. Some get them, some don’t. I’m in the later category. Also at this point any changes to Sync 3.4 will be in the background so it is highly unlikely anything will be noticeable.
Mustangpursuit
California
Mustang GT/CS 2019
Took short time to update for me, no issues as well as uploading to verify update done
19gtaz
Arizona & South Dakota
2021 Mach 1 and 2013 Boss 302
21 Mach 1 with Sync 3.4 Build 21194
It says I'm up to date.
I'm connected to wifi with auto updating.
What am I missing?
Bikeman315
Myrtle Beach, SC
Ira
What am I missing?
Well nothing that you are actually going to see. But it is still worthwhile to be up to date as you would with any computer.
19gtaz
No I mean why does it say I'm up to date when I'm at build 21194, not the latest.
Bikeman315
Myrtle Beach, SC
Ira
Most likely because of an issue with your WiFi and or the auto update system. It’s just easier to use a USB stick. Or call the Ford Sync help number and ask them.
Bikeman315
Myrtle Beach, SC
Ira
The updating over WiFi doesn't really work in many cases. Download and install via USB
He was fine updating via WiFi up until 21194. But if he is showing as up to date then something went wrong. He will not be able to download 23188.
19gtaz
Thanks @Bikeman315 and @Gregs24 . Downloaded on USB and installed in around 10 minutes. I installed it with a battery tender installed and not running. No issues.
Ford has already updated their website to show my new sync of 3.4.23188
Wingnutzz
Woodland Park, CO
David
2022 Mustang EB
I have Wi-Fi updating turned on in my 2022. String signal at my house, but has never updated automatically. Just did the USB update to 23188 today. About ten minutes. Updated my maps last month.
Vlad Soare
Bucharest, Romania
Vlad
2020 Mustang GT 6MT
You were lucky. Battery tenders don't work for this purpose. They can merely supply two to three amps at best, whereas Sync draws in excess of fifteen when up and running. Luckily the update was quick, otherwise Sync would have shut down in the middle of it to save battery.
What actually works for keeping all the accessories, Sync included, running with the engine off without depleting the battery is a 12V PC source. They are stabilized and can maintain a constant voltage at 20 to 50 amps, depending on model.
I'm using this one:
https://www.meanwell.co.uk/power-supplies/enclosed-power-supplies/lrs-600-series-2
I've measured the current draw during a Sync update. It varies between 14 and 17 amps. No battery tender can supply that.
19gtaz
You were lucky. Battery tenders don't work for this purpose. They can merely supply two to three amps at best, whereas Sync draws in excess of fifteen when up and running. Luckily the update was quick, otherwise Sync would have shut down in the middle of it to save battery. Been there.
I'm using this one:
I've measured the current draw during a Sync update. It varies between 14 and 17 amps. No battery tender can withstand that.
Yea, on my other car, the car gave a battery message and tried to shut down multiple times but I just turned it back on before it shut off and finished.
