Octane for gt dd?
Armen
Ontario
2015 Comp Orange Vert
Here in Ontario, I use Shell 91. I'm not sure about other areas, but here it contains no ethanol. When I've stored my cars, I always use this fuel. No stabilizer. No issues, ever.
EFI
Masshole central
5.Br0
The difference between 87 and 93 isn't very significant when you're talking about an NA motor.
You must not know much about motors with that statement. Try putting 87 octane in a 14.1 compression NA motor and see what happens :frusty:
Not that I'm comparing the stock Coyote motor to that, but your statement is vague and partially incorrect. On a stock motor with moderate compression the difference between 87 and 93 *may* be insignificant...but just because a motor is NA doesn't mean it can run 87 just as well as 93.
2015 Silver GT
East Haven Connecticut
2022 Oxford White GT Premium
Well Ford says you can. And they build the motors.;)
Steeeliskt
CA
2015 Mustang GT Manual
The difference between 87 and 93 isn't very significant when you're talking about an NA motor. Stick to tier 1 gas stations and I bet you won't notice one iota of difference. If you get a bad batch of 87 your ECU will sense more knock and pull some timing which will in turn reduce available power but unless you're running a forced induction with a 93 tune, you don't need it.
I never even thought of this. After I went through the first tank of gas from dealership I put 91 one in (in Cali... I had no idea 93 was common place elsewhere). I had to go back to the dealership when that tank was done and they filled it up for me but I knew they were putting 87 in and I could certainly feel the difference. Maybe it was a shitty batch of 87 or from a cheapo gas station. I guess I will try another tank of 87 and see if I notice any difference but the price difference really isn't that big of a deal, even looking at year end figures.
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
Which is odd considering that CA is such a nasty state to deal with when concerning emissions. You'd think they would regulate more consistent fuel mixtures.
I've run a few tanks of 87 from my local Tier 1 stations and haven't noticed a difference in my butt dyno. I'm sure someone, somewhere, has done actual dyno testing to see differences between octane ratings but there are so many variables associated with such a test that it may be difficult to detect what the source of any differences are.
craigsix
overland park ks.
craig
2018 mustang gt
bama did a dyno with 87 and 93 i think.
Cascadia_302
PNW
2015 RubyRed GT M6 Premium
I see some here still confuse higher octane fuel with higher quality fuel. For my stock NA/no tune car if I had to choose between a budget gas with 91-93 octane and a top tier gas with 87 octane I would use the top tier lower octane fuel. But since I don't need to choose I run 92 TT (highest octane for my area).
http://www.toptiergas.com/
King_V
2015 Mustang GT Owner
Sicklerville, NJ
1979 Oldsmobile Cutlass Calais, 1987 Ford LTD Crown Victoria LX, 2015 Ford Mustang GT, 2016 Toyota Prius Two Eco
TrackpackGT
NC
15 Mustang GT PP
As per the owner's manual, use 93 for towing..... It says 87 octane otherwise. I have a SCT on mine, so I run 93. It does have a 87 octane feature in the SCT, maybe I'll give that a try.
Evo_Rob
Mmm... Boost...
Virginia Beach
Rob
Are you just using the preloaded tune?
TrackpackGT
NC
15 Mustang GT PP
Yep. Just downloaded their most recent update, then downloaded the tune.
